Old October 21, 2010, 05:58 PM
SugarJ's Avatar
I find that I always bugger up the threads when I cut screws shorter, so here's a handy tip if you are cutting machine screws down. Thread a nut on first, spin it down below where you want to cut. Cut your screw to length, then spin the nut off, and you won't have any problems starting the nut back on your shortened screw again.
Old October 22, 2010, 07:22 AM
Well I just called the closest Fastenal store to me and they don't have any in stock. I just realized you can check online also for stock if you set a specific store as your default one and all the Toronto locations don't carry any 6-32 2-1/2"! I also checked Home Depot and they only have 2" in stock as well...
I'm getting desperate here lol, if Rona doesn't pan out I'm just going to order online from Fastenal
Edit: Phoned Rona no dice...
Old October 22, 2010, 05:38 PM
Another option would be to buy a long 6-32 threaded rod, cut to lengths, then use nuts/washers at each end.
Old October 22, 2010, 05:51 PM
lowfat's Avatar
Using a washer underneath the fan, next to the radiator might be a tad difficult to install. gs
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 22, 2010, 06:00 PM
3.0charlie's Avatar
Old Aircraft mechanic trick...
Hydro-Quebec is salivating...
Old October 25, 2010, 03:01 PM
sswilson's Avatar
Wouldn't be a problem at all... that end of the rod would be threaded into the rad.... ;)
That said, I didn't see any 6 - 32 rod at the local hardware store. I did however find these (apparently hard to find in 3" lengths) packages of 5 in my local Kent (home depot only had 2").
Manufacturer's name: Hillman
Manufacturer's part#: 126371
Manufacturer's Bar Code#: 08236 88441
Unfortunately, I believe Kent is an Irving subsidiary, and as such is probably not available East of La Belle Province.
Old October 25, 2010, 03:32 PM
Man you're awesome sswilson
You're right though, I don't think there are any Kent stores in Ontario. Did you get my PM btw?
But yeah just wanted to say thanks again for going the extra mile to help me out!!!
edit: typos
Old October 25, 2010, 03:36 PM
sswilson's Avatar
Yep... already in the envelope waiting for a trip to the post office in the AM. We'll see if they charge me more than a normal 52 cent stamp. ;)
  #19 (permalink)
Old October 25, 2010, 03:44 PM
Knowing Canada Post, I wouldn't be surprised!
Let me know the damage whenever you can, I am eager to repay you haha
M4 screws SugarJ Water Cooling 10 December 5, 2011 07:14 AM
where to buys screws and what not Goalieman077 Cases 3 January 7, 2010 03:32 PM
[WTB] Stock HS w/screws for 8800GT/GTS , or Just Screws! Soultribunal Buy/Sell & Trade 15 October 29, 2009 01:48 PM
help with screws phantom_jo Off Topic 9 May 7, 2009 09:41 AM
Thumb Screws WolfBane Off Topic 2 August 4, 2008 05:32 AM
