mcr320 with 3 or 6 fans (without shroud) i read this article at Radiator Fan Orientation and TFC Shroud Testing & Review but what if i use 2x mcr320 with 6 fans (zm-f3)... does it make it huge different? or should i use 2x mcr320 with 3 fans? btw i dont care about noise... |
ok i will put 3 fans per a radiator... since... i can save $36.24.. :0 unless... someone tells me that extra 6 fans is worth... >_>; |
Push pull on such a small radiator w/ a low density fins isn't really needed. If you don't care about noise then just throw on 3 high speed fans and you'll be fine. Preferably some 38mm ones. Like these Koolance ones. K - 120x38mm 2600rpm 116CFM fan FAN-12038HBK K - 120x38mm 2600rpm 116CFM fan FAN-12038HBK [FAN-12038HBK] - $14.99 : DazMode, Canadian PC Water Cooling and Modding Store |
you are correct... koolance 12038HBK (38mm - MADSHRIMPS - Hardware Reviews, Crazy Projects, Modding Tutorials and Overclocking) does perform zm-f3 (25mm - MADSHRIMPS - Hardware Reviews, Crazy Projects, Modding Tutorials and Overclocking) but 14cdn + shipping is not in my budget plus its not available in ncix... i am looking for best value/cfm as zm-f3... btw... i have to cancel my order... because i found this another review unlike my old thread... >_>; edit: according to 120 x 25 mm fan group... zm-f3 is still the best... scythe is not bad too... |
sorry for double post... but i would like to know... Scythe Ultra Kaze 120MM High Static Pressure Fan 38MM 3000RPM 133.6CFM 45.9DBA - DirectCanada is this fan best 120x38 for under 10cdn? i just check the chart... it does perform zm-f3 except noise ratio... |
only available at Panaflo 120mm Case Fan, Medium Flow at Memory Express Computers if it really worths then i could order it... delta is not available in ncix... |
I was planning on sticking a pair of those ultra scythes on my tfc 240. Dont see why a C2D system would require that much for cooling. |
| All times are GMT -7. The time now is 11:11 PM. |
