Old October 28, 2010, 12:50 PM
Okay I put the system together and was wondering if i have the top radiator fans as exhaust and the side radiator fans as intake and then the back fan as exhaust and front as intake is this how you would set it up? Or have all the rad fans as intake?
Old October 28, 2010, 01:14 PM
kruzn4evr's Avatar
IIRC I had mine set up with the top rad as intake and the side and rear as exhaust, I guess it sort of depends on what your cooling with the top rad, if the side rad is cooling one GPU and top is cooling everythinng else then you want the fresh air coming fron the top, at least I found it worked better that way, other way say otherwise.
Old October 28, 2010, 02:56 PM
Its just one loop I have a 655 pump which I think should be enough I mean these aren't monster rads there thin. So it goes res>pump>240rad>gpu>cpu>360rad>res....repeat, basically from what I had been reading people were saying that having the 240 as intake and the 360 as exhaust is what you want, but did you experiment between these two setups or does it really matter?
Old October 29, 2010, 01:10 PM
kruzn4evr's Avatar
I did try it both ways and for my set up, I found having the top as intake worked better, but remember, I had 2 gpu's, cpu and mobo to cool, for your set up you probably wouldn't see much temp difference if any so either way will be fine.
Old October 29, 2010, 06:50 PM
Dazmode's Avatar
If rad is overloaded with components it is better to exhaust top triple rad or your ram will overheat.
Orange Build: Final Video
HTPC Build: Final Video
Old October 29, 2010, 06:57 PM
With the overclocked gtx 470 with (850/1700/1900) overclocks and the 4.2ghz oc on the processor I think the thin radiator gets a little overloaded, I should have said that I put the system together already with just the one 360mm radiator and left the 240mm radiator off(did install it and no kinks on the tubing with side panel closed) but I'm thinking about getting a res now and adding the extra radiator.
Old October 29, 2010, 06:59 PM
kruzn4evr's Avatar
I never had that problem at all Daz, but then again the rad wasn't overloaded and neither should leepord's with just cpu and one gpu, either way, the temps won't vary by than a couple of degrees.
Ahhh...with just one triple rad?...exhaust for sure then.
Old October 30, 2010, 10:51 PM
I'm going to try the side panel radiator mount for now, but eventually I think im going to remove the hdd cage and put the 240 rad up front and just move my single hd to a 5.25 slot this would make it simpler and neater. Thanks for the advice guys ill post some pics once I have all the radiators installed.
  #19 (permalink)
Old November 3, 2010, 05:26 PM
So I finished the (rebuild) installation finally and noticed a drop of 6 degrees in temperature with the second radiator. The loop is setup as res>pump>240 rad> gpu block> cpu block> 360 rad repeat. The 360 rad has air flow exhausting and the 240 has air flow as intake. Had to use anti kink coil for the 240 rad otherwise it would well kink lol.
  #20 (permalink)
Old November 4, 2010, 03:57 AM
KaptCrunch's Avatar
good job, liked the high rez
Tags
haf932 , swiftech , watercooling
HAF 932 stencil mo' power Cases 6 April 13, 2010 09:10 PM
HAF 932 WC Setup Pax Water Cooling 10 January 18, 2010 09:19 PM
HAF 932 Upgrade icepizza Case Mods, Worklog & Gallery 9 January 7, 2010 07:46 AM
[WTB] HAF 932 or Cosmos S miggs78 Buy/Sell & Trade 9 September 24, 2009 07:56 PM
Operation HAF Baked! Cooler Master HAF 932 Lithotech Case Mods, Worklog & Gallery 42 December 17, 2008 10:22 AM
