Old October 9, 2010, 10:19 PM
CTA's Avatar
CTA CTA is offline
Default mrc320 too big
i just measure something in the case... i think mcr 320 is too big... i just like mcr 220 for reasonable size...
so i wonder... how do you compare preformance from mrc 320 vs 220? less than 5 degree difference?
btw i dont mind to use triple or quad radiators... >_>;
Old October 9, 2010, 10:26 PM
MpG's Avatar
MpG MpG is offline
Radiator performance scales pretty linearly compared to size, so a double-rad will be able to dump 2/3 of the heat that the triple can, at the same air-water temperature difference. The temperature difference that you'll see depends entirely on what you're trying to cool and how much heat the hardware dumps into the water.
Old October 9, 2010, 10:45 PM
CTA's Avatar
CTA CTA is offline
if you said that its pretty linear performance then what about gtx 280 sli setup? will dual radiators able to handle it fine? or perhaps quad radiators is better idea?
Old October 10, 2010, 09:05 AM
MpG's Avatar
MpG MpG is offline
Until just recently, I was cooling both my GTX280 and my i7 920 @ 4.0GHz on a single MCR220, with fans at only ~800rpm, and core temps were in the 40's. While you may be able to get a few more degrees with a larger radiator (or faster fans), a double rad will handle a pair of 280's.
Old October 10, 2010, 11:01 AM
CTA's Avatar
CTA CTA is offline
serious?
just curious... mcr220 in sandwidth is good idea.. or not? two fans between the radiator... or add more two fans at top of the radiator...
Old October 10, 2010, 11:23 AM
Lpfan4ever's Avatar
Don't stack them. All you do is blow the heat from one radiator into the other. Other than that, I can't really give any info into your question.
Originally Posted by encorp
Code:
<firebane> slightly used
Old October 10, 2010, 11:24 AM
CTA's Avatar
CTA CTA is offline
well... how about this... did it work?...
btw thats fine... its not easy to find the answer... i actually search it online...
Old October 11, 2010, 07:03 PM
MpG's Avatar
MpG MpG is offline
Stacking doesn't work without very high rpm fans - as LP mentioned, the first radiator heats up the air so much that the second radiator can't do anything meaningful, but the two radiators slow down the air so much that performance can actually turn out worse than with a single radiator.
Old October 11, 2010, 07:34 PM
That's pretty much what I've found as well. You'd be better off with two separate ones in series, or even making use of a single 120 rad on the exhaust of the case IMO.
Old October 11, 2010, 08:28 PM
CTA's Avatar
CTA CTA is offline
i got you guys... i will drop the radiator stack idea... i just hate radiator's large size... its not easy to cramp it into the case... mid or full tower is much suitable imho... but i am trying to put radiator on normal case... >_>
just curious... which is better... mount the radiator vertically at back of the case... or mount the radiator at top of the case.. are they will doing fine?
Big Bang Help Jamula66 Troubleshooting 19 May 13, 2010 02:24 PM
The Big 4 cmac79 Off Topic 4 December 22, 2009 12:13 PM
When does a Cooler Get too Big? Soultribunal Air Cooling 23 January 20, 2009 11:28 PM
How big of a rad do I really need? Skyllz Water Cooling 14 September 23, 2008 11:27 AM
The Big Beaver Mulder Off Topic 1 April 25, 2008 07:38 AM
