Old October 11, 2010, 09:45 PM
Outside will obviously get colder air, but If possible I'd have it internally for aesthetics.
Old October 11, 2010, 10:13 PM
CTA's Avatar
CTA CTA is offline
of course outside of the case.. but horizontal and vertical... does they matter?
Old October 11, 2010, 10:17 PM
I don't think there is any significant difference. However, where the in/outlets are does make a difference to flow. You want them facing down for horizontal, or at the bottom for a vertical mount.
Old October 11, 2010, 10:38 PM
CTA's Avatar
CTA CTA is offline
very interesting info...
so i will put two (seperate) radiators at top of the case...
thank you for tips... ;]
Old October 12, 2010, 06:20 AM
Fudd Rucker's Avatar
What you need here is to get creative with a dremel. I managed to cram a whole lot into an antec 300 lol. Ill show pics later on in the week when the parts get here for me to finish my build.
I couldnt think of something snarky or interesting to put here this time around.
Old October 12, 2010, 10:50 AM
CTA's Avatar
CTA CTA is offline
:o antec 300 is very tight case for watercooling...
just recent, i re-measure everything... and i possibly put two mcr320 on back or left side...
Big Bang Help Jamula66 Troubleshooting 19 May 13, 2010 02:24 PM
The Big 4 cmac79 Off Topic 4 December 22, 2009 12:13 PM
When does a Cooler Get too Big? Soultribunal Air Cooling 23 January 20, 2009 11:28 PM
How big of a rad do I really need? Skyllz Water Cooling 14 September 23, 2008 11:27 AM
The Big Beaver Mulder Off Topic 1 April 25, 2008 07:38 AM
