ok so here's the scoop. When I first built my Rig, I got a free sealed water cooling setup from a friend. it includes a D-tek Fuzion v2 cpu block, two D-Tek FuZion GFX 2 GPU Blocks, a standard 240mm rad, a no-name pump, and some anti-kink tubing.
since I have no local place to get tubing and it doesn't have a reservoir, I just left it all together and tucked the un-used blocks away in the 5.25" bays. I'm noticing lots of bubbles in the tubing, and am getting ever-increasingly annoyed by the extra tubes and blocks. I would like to replace the tubing and the radiator (threads are badly damaged in rad) and get a reservoir. I cant tell what kind of fittings I have until I take my setup apart since they have some metal clips that are crimped on, so lets assume I'll get new fittings as well.
My setup is a i7 920, Asus P6T SE mobo, and a Corsair obsidian 800D case. I'm looking at being able to have the i7 at 4Ghz constantly.
So I need:
Radiator (at least a 240mm)
Reservoir (5.25" bay preferred)
Fittings ( Im sure they should all be G 1/4)
Tubing (3/8" is plenty unless otherwise suggested)
I guess it doesnt really matter where I order from, the only place ive ordered from is FrozenCPU.com. I dont really have a budget, but I dont really want to go crazy either. shouldnt really be over $200 right?
anyway, any help would be greatly appreciated. thanks
here is my current WC-ing setup
my watercooling on Twitpic
