Old October 21, 2010, 09:52 PM
Jackquelegs's Avatar
My first setup went smooth as butter. Surprisingly it was a dual loop system built onto a CM690 case...It took a lot of planning and swearing but it did the job.
HOWEVER, during maintenance a bit later, I fried the mobo
Iapetos
Zephyranthes
Old October 21, 2010, 10:07 PM
CTA's Avatar
CTA CTA is offline
please tell me what happen about maintenance... like you supposed to change the water... eh?
this thread is very useful... thank you ;]
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old October 21, 2010, 10:36 PM
Yep, changing the coolant and adding some new blocks. Had a micro-leak on the GPU block that seeped onto the mobo
Iapetos
Zephyranthes
Old October 21, 2010, 10:45 PM
lowfat's Avatar
I also have learned not to use barbs w/ recessed orings on the majority of Swiftech blocks. Have tons of leakage problems in the past because of it.
Old October 21, 2010, 10:59 PM
I went straight to compression fittings for my first custom waterloop. Just have a bad feeling with clamps, I knew I would muck it up someway even though they are the cheaper alternative.
Old October 21, 2010, 11:07 PM
CTA's Avatar
CTA CTA is offline
can you please explain a little more? use barbs without o-ring on swiftech blocks?
Old October 21, 2010, 11:47 PM
Forgive the "this" response. BUT EXACTLY THIS. Damn MCW60 didn't like those barbs.
Iapetos
Zephyranthes
Old October 22, 2010, 11:43 AM
G777's Avatar
First foray into watercooling was about a year ago, all went pretty smoothly. Over the next 6 months I changed a few things around, so I became very familiar with the process of draining, refilling and leak testing the loop. Next I decided to upgrade my video card, so went and grabbed a Koolance block and a brand spanking new GXT480 superclocked.
After installing the block, I leak tested for 2 hours and thought it was good to go. Powered the system up, started running F@H and went to have a nap... woke up a couple hours later to a small lake of blue coolant under my case, and a good sized puddle all over the nice new fermi. The tubing had almost completely come off where the run from the cpu went down to the gpu; I imagine I must have pulled on it trying to wiggle the card into place.
So I've gone back to leak testing over night
PS: I prayed to the computer gods that I would always be faithful to those responsible if my rma was approved for the card... so i always buy from Ncix and my next video card will be another Evga
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Anyone have any experience with BestDirect.ca? backpack New Builds 17 February 1, 2011 10:17 PM
My SSD Experience Canzara Storage 3 November 26, 2009 04:17 PM
My NCIX experience go flames go Off Topic 93 April 16, 2009 11:40 AM
My experience with A$US RMA Brian Off Topic 21 January 30, 2009 04:33 AM
DC Experience JD Off Topic 25 January 5, 2009 07:45 PM
