Old October 5, 2010, 08:47 AM
Default Fan advice
I would like to change the 3 scythe ultra kaze for 3 xigmatek 120mm fan one...
The thing is that I don't know if I'm gonna lost a lot or not?
Scythe kama kaze 3000rpm, 131 cfm, high static pressure
Xigmatek 1500rpm 61 cfm
What should I expect?
Will I need to place 6 fan to get the same performance as before?
I'm doing this for esthetic's and NOISE!
I never use the fan at full speed, 45 db x3 is unacceptable even when gaming.
Using a fan controller(scythe one) and a swiftech triple radiator.
thx!
Old October 5, 2010, 09:15 AM
martin_metal_88's Avatar
Edit : Just saw it was for a rad. You are better with the Gelid wing 12 or the scythe gentletyphoon 1450 and 1850 RPM.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old October 5, 2010, 01:00 PM
I won't put green or yellow or even green fan in this setup.
It's orange or black.
But the question is, will I lost alot in performance or not?
Old October 5, 2010, 01:02 PM
JD JD is offline
My GT 1450s seem to do quite nicely on my HWLabs SR-1 360. Nice and quiet too.
Old October 5, 2010, 01:04 PM
You will probably lost some but 1, 2 degree? so who cares? just for the noise that will be cut A LOT! it totally worth it.
Ask for more
Martin_metal_88
Old October 5, 2010, 01:08 PM
aaahh that is what I wanted to know!
Anyways I might get an Admiral rad... waiting to see the review first.
Old October 5, 2010, 01:27 PM
Lol if you get the admiral 700 even without fan it will be nice:P Be aware that with these rad you will need fan that have good pressure ( not CFM ). GT's will work fine.
Ask for more
Martin_metal_88
Old October 6, 2010, 05:43 PM
And how the hell do you know the spec?
Tried many forum and I can't find anything...
Old October 6, 2010, 05:58 PM
lowfat's Avatar
No one knows really. But it is believed that they should have rather low air resistance.
Old October 6, 2010, 06:37 PM
Talam:) Most of the big and effective rad have seriously close fin so need big airpressure...this is known for long.
Ask for more
Martin_metal_88
Fan advice please! Peanutmc Air Cooling 1 September 27, 2010 09:30 AM
Fan advice Kilauea Air Cooling 3 October 15, 2009 04:59 AM
Need fan advice. Caznoob Air Cooling 3 January 29, 2009 12:20 AM
4870 fan: Catalyst auto-fan is too aggressive Bucklaz Video Cards 4 January 7, 2009 11:21 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
