Old October 6, 2010, 07:13 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by martin_metal_88 View Post
Talam:) Most of the big and effective rad have seriously close fin so need big airpressure...this is known for long.
You mean, like HWL's SR1 series? Or Thermochill's PA series?
Radiator surface area, core thickness, and fin density are all different things, and they can all be adjusted independantly according to what kind of performance the designer wants. Right now, we don't really have any frame of reference with which to estimate the Admiral's performance, since it uses a completely different design.
Old October 6, 2010, 08:25 PM
martin_metal_88's Avatar
Hm true, admiral seems to be like big dissipating tube. If that the case then you still need more air pressure than airflow. But let's see when they will be released :)
Old October 16, 2010, 11:29 PM
Ahhh love!
Less noise and only a few degree more.
Old October 17, 2010, 11:29 AM
ottoyu34's Avatar
seems like you will kill your ears if you don't switch earlier.
GT AP-14 1450rpm serves my needs.
Old October 18, 2010, 04:03 PM
The difference is big and I really like that!
The fan that I had use is for thematic only.
Fan advice please! Peanutmc Air Cooling 1 September 27, 2010 09:30 AM
Fan advice Kilauea Air Cooling 3 October 15, 2009 04:59 AM
Need fan advice. Caznoob Air Cooling 3 January 29, 2009 01:20 AM
4870 fan: Catalyst auto-fan is too aggressive Bucklaz Video Cards 4 January 7, 2009 12:21 PM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
