Old December 14, 2007, 05:52 PM
Cptn Vortex's Avatar
Default Cooling Dual X5355's.....HOT suckers!
Hey all, I'm working on a current build right now. It's quite the machine. Dual Quadcore X5355 2.66GHZ cpu's, 16GB RAM, Dual 8800GT in an Antec P190. Quite the sweet system. We were going for as silent as possible with such a beast, so threw on a pair of Thermalright HR-01 - X coolers. The heatsinks are massive, had to remove the giant side fan, as well as the Dustfilter/fan bracket to get the side panel on! Anyway, running 8 instances of Prime right now (that was a pain to get started!) and with the fans on low, I was hitting mid 90's across all cores! Yikes! I now have the fans on medium and it seems to have leveled off at about 75 degrees. Also, I checked Intel's spec on this CPU, and it seems the Vcore range should be from 1.16-1.2V, but this Supermicro board seems to be feeding it a steady 1.35V, and there is NOwhere in the BIOS to make changes to that.
Any ideas?? Am I safe??? We're talking about 2 x $800 CPU's here!!!
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old December 14, 2007, 07:10 PM
3.0charlie's Avatar
First and foremost, this thread needs pics.
Second, that's wayyyyyy tooooooo hot! Is this at stock speeds? Are you sure it's 75C and that the Vcore is 1.35V? Make sure you have good contact between the CPUs and HSFs, double check the BIOS, raise the fan speed to the max and check the temps again.
John
Old December 15, 2007, 09:56 AM
Yeah, I can post some pics. Don't have my camera here at work today though, will have to wait till monday. Anyway, it is 75 with the fans on medium. The heatsinks are on right, (btw those thermalrights are a B*TCH to install on a Dual socket board, seriously...) and there is good contact. I'm still going to re-seat it today. See if I can't get some better results.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old December 15, 2007, 01:19 PM
Ok, just zip tied 2 x 120mm 1200RPM scythe Slipstreams to both heatsinks, in push/pull config, and it brought the load temps down to 64 per core, on the hottest cores. The other cores are mid 50's. That is with all case fans on low! This thing is a beast! Can't wait to take pics hehe. Also want to try a run of 3DMark06....
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old December 15, 2007, 01:33 PM
werty316's Avatar
Now that is one freakin' sweet rig
Obviously watercooling those CPUs would be a good idea.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old December 15, 2007, 01:41 PM
I would watercool it if I could, but it is not my computer, oh well. Lucky SFU gets it instead.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old December 15, 2007, 01:44 PM
werty316's Avatar
Why would a Uni need such a powerful computer like that? Do they have some sort of gaming course where you play games all day?
Old December 15, 2007, 01:45 PM
Jack Rabbit's Avatar
ok... 8 instances of Prime95? You might as well take those chips out to the alley and beat them with a hose for a while too. Do you expect this box to need to do that kind of work in production?
Also, is it a workstation or a server? Servers under that kind of load are expected to scream like banshees to cool properly.
Old December 15, 2007, 01:47 PM
werty316's Avatar
The question as to why it needs to 8800GTs since it'll be going to a Uni has me.
Old December 15, 2007, 01:51 PM
Well, the main purpose is to do repetitive simulation exercises that eat tons of RAM and take many days. Mainly mathematics. And it needs to be silent, which I have accomplished! Also, the dual 8800GT's are for his 3 x 30" monitors..... Yeah, pretty sweet.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Dual CPU Thread MarshallX Case Mods, Worklog & Gallery 50 February 2, 2010 10:48 PM
Dual boot question SpateD O/S's, Drivers & General Software 17 March 8, 2008 05:11 PM
Dual or Quad?? BALISTX CPU's and Motherboards 4 November 22, 2007 12:36 AM
dual boot how to ? Jim Storage 18 August 11, 2007 05:45 PM
Dual monitor problems ragenrok Video Cards 4 May 4, 2007 11:34 AM
