Old October 3, 2010, 01:14 AM
CTA's Avatar
CTA CTA is offline
Default watercool advice [me-n00b]
i just quickly search some information and i understand mostly... but you know i cant know everything about watercool... and of course i dont have much experience...
first here is what i did read... i choose useful articles...
http://www.tomshardware.com/forum/25...rcooling-guide
Water Cooling Parts Guide 2008 V1.2 - EXTREME Overclocking Forums
Water Cooling Guide for Beginners Overclockers Tech
D-Tek FuZion v2 CPU Block, work on an i7? - XtremeSystems Forums
Core i7 CPU Water Block Roundup
Skinnee Labs | Core i7 CPU Block Roundup #2 (old and latest one is at Skinnee Labs | EK Supreme HF )
now i realize... that my watercool setup that i bought (probably last year... cant remember) is not great as present... isnt it? i also bought 2 gpu blocks for gtx 260 too...
well the short long story; i want to set up the watercool for show off and learning at same time... but i dropped the idea for unknown reasons... sorry i dont remember... probably i dont care anymore or lazy...
so i accidentally saw the thread at buy and sell... that mm88 sells whole watercool setup which is pretty good deal... http://www.hardwarecanucks.com/forum...-out-fast.html
so should i keep my watercool setup because it didnt make a big different... or should i get that watercool setup? do i need to buy more or replace the part to better one? any advices would be helpful...
thanks...
edit: about my opinion of mm88's w/c setup... supreme hf seems best cpu block in the marker... i am not sure about pump... probably fine... and i think i should get better radiator such as thermochill pa120.3.. well mc320 is good for value budget...
oh btw.. the not-ready-yet computer specification would be
hx1000
i7 950
ga x58a ud9
g.skill ripjaws 3x2gb 1600
vertex 2 60gb
seagate 7000.12 1tb
undecided about the case or make my own case... because of xl-atx format
Old October 3, 2010, 05:40 AM
KaptCrunch's Avatar
pass on the Feser One - Cooling Fluid - UV BLUE
its a good deal , i see one a silver fitting, just add a silver coil using DistilledWater.
i also see thermo-pads for video heat sinks
Old October 3, 2010, 06:53 AM
bautisj's Avatar
True,
I suggest just DT Water and silver coil or PT nuke ;)
Intel Core i7 2600k
ASUS P8Z68-V Pro Z68
16GB Corsair Vengeance Blue
EVGA 570HD
OCZ Vertex 3 120GB
1TB WD Black
NZXT Phantom White (Full Fan Upgrade)
Silverstone Strider 850w (GOLD)
Windows 7 Ultimate
Old October 3, 2010, 04:19 PM
CTA's Avatar
CTA CTA is offline
darn its sold... oh well... i alawy can get new one ;p
so here is the "good to best" products... little similar.... and use my old stuff...
- EK-Supreme HF - Acetal-Nickel or Plexi-Nickel or Full Nickel ? 70cdn to up
- OR Swiftech Apogee XT Extreme - 55cdn to up
- Swiftech MCR320 [owned]
- Swiftech MCP655 pump(with variable speed) [owned]
- 2x 260gtx dtek gpu << might use...
misc parts
can i use that box reservoir (MCRES Micro Revision 2)? fillport? etc?
btw.. yes i dont like blue uv... i prefer clean and nice... ;p
dt water + pt nuke = messy... Holly Shit....My beloved **HK3** WTF is this Gunk - RRTech...The SOURCE for Extreme Liquid Cooling
what do I need to watercool my gtx285 Shadowmeph Video Cards 9 June 29, 2010 04:21 PM
Watercool my Q6600 or Upgrade? Skyllz CPU's and Motherboards 9 September 10, 2009 09:16 AM
First Watercool - Advice? LegendofJubei Water Cooling 6 September 8, 2008 07:25 PM
What Watercool kiy to buy jasonmoreau Water Cooling 6 February 11, 2008 11:25 AM
Yes, I Am An OC N00b! DaBruuzer Overclocking, Tweaking and Benchmarking 9 January 28, 2008 09:32 AM
