Old December 12, 2007, 08:54 PM
chibi_man's Avatar
Default Curious about buying heat pipes.
I have a creative idea. But it involves using heat pipes.
So I am curious if there is any chance I can actually buy heat pipes with flex line. My knowledge of heat pipes is limited, so I'm just looking for a yes or no to if I can buy them separate.
_____________________________________
If you can't beat it... SMASH IT!!!
Old December 12, 2007, 09:14 PM
MpG's Avatar
MpG MpG is offline
I don't think I'd get my hopes up for any cheap solution. The idea of a fully flexible heat pipe doesn't sound likely, since the heatpipe's operation relies on a reasonably consistent internal volume, which flexible pipes might change.
I'd certainly be interested to learn otherwise, though.
Old December 12, 2007, 10:00 PM
chibi_man's Avatar
As would I right now.
Heat Issue Lyxtwing Video Cards 8 March 14, 2008 08:35 AM
Buying New Ram: OCZ vs Corsair tgraszat14 RAM 2 February 5, 2008 10:27 AM
Buying from Direct Canada? Read This. Epsillon Off Topic 114 January 25, 2008 06:01 PM
New to OC and buying a new system... need advice Spblue Overclocking, Tweaking and Benchmarking 3 December 5, 2007 10:21 AM
RAM Question - Buying Tonight (09/26/07) - Kandorf RAM 22 October 26, 2007 08:28 PM
