Old September 22, 2010, 10:30 PM
Default Would this pump work?
I would like to use this X2O 750 Dual 5.25in. Bay Reservoir Pump res and pump combo to cool my 5850. The rad I will be using is a MCR320 from swiftech and the gpu block is the EK-FC5850 full cover nickel-plexi block. I will be at some point be adding a second 5850 and would like to know if this pump would work.
Old September 23, 2010, 04:41 AM
kruzn4evr's Avatar
It should work fine with one or two 5850's, I'm not a big fan of the built in pump/res personally but others who use it say it works pretty good.
Old September 23, 2010, 05:16 AM
MpG's Avatar
MpG MpG is offline
No worries, it'll be fine. If you had a fairly restrictive CPU block in there as well, the flow rates might be a little weak, but EK's blocks are pretty good these days for restriction.
Old September 23, 2010, 08:28 AM
Thanks this is what I was wanting to hear. I did think it would not be a problem but I still wanted to run it by people who have more experience in water cooling.
Old September 26, 2010, 04:59 AM
KaptCrunch's Avatar
Voltage: 12V (4pin) PWM type pump, does your MB support 4 pin CPU fan header to get the best out of pump
spec: 750 lph = 198.15 gph
head: 1.8m = 5.9 ft
Old September 26, 2010, 03:37 PM
I believe the pump is powered off a 4 pin molex not a 4 pin fan header.
Old September 26, 2010, 07:11 PM
KaptCrunch's Avatar
correct molex thought was pwm "The pump is the same great 750lph low noise pump used in the previous model with improved electronics to increase long term reliability." XSPC didn't post electric spec's for this pump for $3 more go with D5
Old September 26, 2010, 10:23 PM
That is just for the res I would have to buy the pump adding another $60 so I went with the X20 750 because it comes with a pump.
Attempt #10 to get work failed, and no other work to do. LaughingCrow HardwareCanucks F@H Team 3 May 5, 2010 08:29 AM
Significance of the pump? biff Water Cooling 2 February 15, 2010 06:07 AM
[WTB] Water pump BrokenHalo83 Buy/Sell & Trade 13 October 23, 2009 02:07 PM
Can my pump do this? SugarJ Water Cooling 8 June 10, 2009 11:28 AM
Pump rattle? SugarJ Water Cooling 6 April 26, 2009 10:02 AM
