Old September 16, 2010, 04:09 AM
Im going this route aswell, Looking forward to seeing some pics.
Old November 7, 2010, 07:27 PM
Better late than never eh? lol Sorry guys :D
Specifically the top mounted rad. As you guys can see, I used the little rubble dampeners to create a level surface for the fans to make it a little more air tight. I pulled out the corner of the closest fan to show that I cut the rubber there as it would have to go over top of the crossbeam, creating a bump and making it less flat for the fan mount.
Bottom view, only pic I have showing the clearance about the RAM/CPU socket. It's impossible to mount fans in push/pull in the HAF X with a 62mm thick rad like the TFC Xchanger 360, HWLabs 360 GTX, etc.
More pics if you guys are interested and need ideas for your HAF X builds:
ImageShack Album - 27 images
Tags
bleed , radiator , top case , top mount
Cosmos watercooling question - top-mounted rad... Synth Water Cooling 8 July 19, 2008 12:03 PM
Help me chose a *Flat TV*! Patriote Display Units 57 July 2, 2008 05:27 PM
clear vs black tube: how do people bleed their systems? elninio Water Cooling 13 June 10, 2008 10:09 PM
Top mount radiator - what would I need? JayDee Water Cooling 22 July 17, 2007 06:21 AM
