Old September 12, 2010, 02:11 PM
Question Is it really possible to get all the @#%$ out of a Thermochill PA rad????
I'm in the process of transferring my loop into a 700D and when I drained the current loop there were obvious flux flecks in the water.
Prior to initially installing the Thermochill PA120.3 I followed the cleaning instructions found on this and other forums. Hot water soak / shake it like it owes you money / repeat I can't recall how many times until what appeared to be a clean water rinse.
Now I have a PA120.2 to add to the loop and it and the PA120.3 are proving to be the bain of my existence for the past 2 days. I've even used a 1/3 diluted vinegar solution shake for a couple of seconds followed by repeated water shakes/rinses and a tap hook-up that allows a hot water flushs for hours at a time.
But I am still getting @%@$^ flux in the rinse water.
Has anyone actually been able to completely clean a Thermochill rad? If you have could you please share your secret!
Cheers, Talon
Old September 12, 2010, 02:18 PM
Sushi Warrior's Avatar
RRTech...The SOURCE for Extreme Liquid Cooling - View Single Post - Thermochill Radiators - Removing Flux (solution found !!)
So yes, but no. Guess you'll just have to live with the flux?
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old September 12, 2010, 03:20 PM
Dazmode's Avatar
That is one of the reasons why we don't sell those... because they are pain in...
Orange Build: Final Video
HTPC Build: Final Video
Old September 12, 2010, 05:54 PM
AmuseMe's Avatar
I have one of the RRT PA120.3 Quite happy with my 100% flux free radiator :D
DEAD CA$H
Old September 13, 2010, 01:17 PM
BigDogg's Avatar
I used isopropyl alcohol to get the flux out of mine.. I let it sit for about 10 minutes and then shook it like crazy and it seemed to be clean after that..
Old September 13, 2010, 05:58 PM
AmuseMe's Avatar
It's not clean, trust me The PA's will forever be dirty unless industrial cleaning is applied
DEAD CA$H
Old September 14, 2010, 06:21 AM
Rison's Avatar
lol @ "shake it like it owes you money".
I had a 120.2 for a few months, sold it and bought a TFC triple rad from Daz. That's your best solution. :)
I'll learn to manage my anger, when people learn to manage their stupid.
Old September 15, 2010, 10:42 AM
BigDogg's Avatar
I don't get it? Thermochills are the top of the game when it comes to RAD performance. I can't get any flux to come out of my rad after I used the alcohol. Over at Xtremesystems the PA120.3 is usually recommended if you can find it.
Old September 16, 2010, 07:48 PM
OK...
Checked around locally for a shop that could do ultrasonic cleaning, no luck. Found a rad shop that can do boiling acid dips but they wanted $100 per rad, I politely told the guy he was out of his mind.
So, I've done the vinegar full soak for 30 min, drain 1/2 and shake and rinse, used 4L total, baking soda mix 4 times, isopropyl alcohol, 3 bottles worth and more hot water shakes and got them to the point where a distilled rinse looks crystal clear. No flux skim on the surface and clear water...GREAT!!
But...and it always seems there is a but with these rads, when I leave the 120.3 empty overnight and rinse the next day I get flux like I was just starting. Two rinses and I'm back to clear but I'm and at the point where I have mounted the rads and if they my multioption I'll just replace it and the rads when I redo the loop for the X58 install early next year
Old September 17, 2010, 06:21 AM
Rison's Avatar
I think it's hit and miss with the rads - I know I had a bad one.. I shook the hell out of mine for days with isopropanol before putting it in line, a week or so later.. I saw bits in my resevoir and had to clean out the loop. Did this twice, then as I said before - sold it off and bought a TFC from Daz.
The people who recommend the thermochills probably never had issues with one.. it's a fairly well known problem.
[FS] Thermochill Rad mhw100 Buy/Sell & Trade 4 March 4, 2010 07:09 PM
thermochill rad g3/8 adaptors? cozmosland Water Cooling 2 January 23, 2010 01:18 PM
[WTB] A couple Thermochill PA120.2 Rad's rai_polo Buy/Sell & Trade 2 November 4, 2009 05:25 AM
[WTB] Thermochill PA120.3 Chilly Buy/Sell & Trade 3 April 23, 2009 11:47 AM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
