Old September 14, 2010, 12:44 PM
is distilled water + silver kill coil enough to prevent algae and to keep my loop clean?
Cant find any stores that carry silver kill coils, any alternatives?
Old September 14, 2010, 12:56 PM
Dazmode's Avatar
You can go with less expensive EK 2.2 pump + 2 barbs.
You won't gain much with XT over less expensive LT. May be 1 degree.
Orange Build: Final Video
HTPC Build: Final Video
Old September 14, 2010, 02:12 PM
lowfat's Avatar
No place in Canada sells the iandh kill coils AFAIK. Performance-PC's does stock them in the USA though. Any 99.9% silver piece thrown in a resevoir would work though.
Old September 14, 2010, 02:20 PM
Okay, 1 degree is kinda within the margin of error which means they are practically the same?
the ek 2.2 pump is tempting price wise but i cant seem to find any reviews on it. is it capable of running my loop 24/7?
If i plan to upgrade to i7, will you still recommend the supreme lt?
Thx in advance.
Might find those on ebay... thx
Old September 14, 2010, 03:17 PM
lowfat's Avatar
On average the Supreme LT will be about 4C higher than the Swiftech XT.
Skinnee Labs | Koolance CPU-360
Old September 14, 2010, 03:33 PM
Dazmode's Avatar
Thx in advance.
Well, XT is not my personal favorite but it definitely will give you 1 degree better temps then LT. LT is still OK for i7, I used it for few months without any issues.
While Laing pumps are everybody's favorite, there is nothing wrong with Jingway pumps. Tons of people use those.
If you short on cash make it lean setup. We have liquidation going on with Swiftech rads, reservoirs, tubes,...grab one while they still in stock, can't get this for lower then we have. WC can get very expensive very fast. Before you know you are already off for big bucks. Speaking from experience
Tags
water cooling
Budget Card for Photoshop & 3ds bkh2 New Builds 11 February 21, 2010 05:03 AM
$625 Budget Rig For Graphic Design & Flash Animation backpack New Builds 10 November 17, 2009 04:17 PM
Snipers Sub Compact H2gO Sniper Case Mods, Worklog & Gallery 14 December 13, 2008 12:52 PM
Compact 9600GSO cooling? chrisk Air Cooling 1 December 5, 2008 07:23 PM
WTB:Swiftech H20-220 Compact Ken_C Buy/Sell & Trade 3 November 4, 2008 07:59 PM
