Old August 29, 2010, 06:22 PM
martin_metal_88's Avatar
Default Cleaning a CPU block
Hello everyone! I am thinking of cleaning my CPU block since I have to drain my loop soon. So I was asking myself...what is the best thing to use to clean it all. After some reading I find that most of you seems to be using Ketchup but...is it real heinz ketchup or just a name for another product?? So what is the best thing to use to clean my block?
Old August 29, 2010, 06:30 PM
lowfat's Avatar
There was just a thread about this on XS. Ketchup works decently from my experience but not perfectly. Tarn-X or another copper/metal cleaner would likely work better.
Cleaning Blocks? - XtremeSystems Forums
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 29, 2010, 06:42 PM
Ho I see. I never figure out to use my hotdog favorite garniture in my computer. Thx alot lowfat!
Old August 29, 2010, 11:56 PM
Sushi Warrior's Avatar
Ketchup worked miracles on my Supreme LT. Don't be stingy with it, and give it an hour or so. Maybe more if it really is dirty. Then give it a nice rinse in DISTILLED water. Tarnx may return the original shine better but ketchup should work better to remove stuff stuck on.
Old August 30, 2010, 12:17 AM
Ketchup and a tooth brush ! Works perfect. There are other methods that also work but hey, everyone has ketchup.
Old August 30, 2010, 01:07 AM
Make sure it is a new tooth brush in that case, there is some nasty bacteria on used ones that could give you algae problems or something along that line.
Old August 30, 2010, 01:24 AM
haha there cheap enough I dont see why you wouldnt
Old August 30, 2010, 10:30 AM
lowfat's Avatar
I used the same used old toothbrush to wash my blocks and my shoes.
Queen of Dreams WIP
Big Lian Li
Complete
Old August 30, 2010, 11:14 AM
+1 for Ketchup dip.
Make sure there is enough to fully cover all of the copper. Then use a toothbrush and scrub till shiny. Rinse off and DRY IT WELL otherwise you'll get waterspots and have to do it all over again.
heatware
Old August 30, 2010, 01:20 PM
gingerbee's Avatar
well a tooth brush yes i have never needed to use Ketchup. blocks never get that dirty on me and all i run is water and toyota/anti-freeze works great.
CPU block for LGA1156? Deeival Water Cooling 9 September 10, 2009 10:08 AM
CPU and cpu block questions miggs78 Water Cooling 7 August 10, 2009 01:14 AM
[WTB] Cpu block donkon Buy/Sell & Trade 1 May 15, 2009 09:09 AM
Cleaning Out Thermal Paste On CPU shayan288 CPU's and Motherboards 17 March 24, 2009 09:37 AM
[WTB] CPU Water Block Lpfan4ever Buy/Sell & Trade 10 March 4, 2009 07:00 AM
