Old August 24, 2010, 10:37 PM
Default Some new toys, some questions
I am upgrading my tj07 case to the MM Ascension, which I got the case from Lima here(good person to dealt with btw). I do have some questions here and I wish fellow canucks can help me out here.
Here is what I currently have right now (some new and some is currently using)
2 MCP655
1 Swiftech XT
3 Thermochill PA120.3
1 EK X58 Classified full size block
2 EK tops for MCP655
13 Gentle typhoon 1850 fans
1 Frozen Q Red Classified res
I want to know if the 1 MCP655 with ek top good enough to run 2 PA120.3, swiftech xt and the ek x58 classified block?
If so, I can make one more loop for my GTX480
the CPU loop will be res>pump>pa120.3*2>swiftech XT> EK x58 block <--Will one MCP655 with top handle it no problem?
If so, I can go to daz and place and order on the ek 480block with back plate
Old August 24, 2010, 11:19 PM
SugarJ's Avatar
You should be fine with that CPU/mobo loop, although 2 PA120.3 rads is overkill. I've got one Feser 360 with a MCP655, Heatkiller, X58 block and an EK block on my 470, and temps are fine.
Old August 25, 2010, 06:16 AM
kruzn4evr's Avatar
+1 ^^ Sugar is right, you really only need one 120.3 for the CPU/mobo, I use a mcr220 with push/pull for CPU/mobo and it does a great job all things considered, a single 120.3 will be more than enough.
Old August 25, 2010, 06:27 AM
gingerbee's Avatar
yes it is but a single triple should work fine
Old August 25, 2010, 11:38 AM
I know it overkill but I want to make use of the parts I have.
Old August 25, 2010, 12:17 PM
MpG's Avatar
MpG MpG is offline
Yeah, nothing wrong with using just one pump there. And as for running two rads, just look at it as an opportunity to run slower fans without losing rad performance.
Old August 25, 2010, 08:12 PM
Lima's Avatar
Reminds me of my set-up. I had 1 MCP655 pumping water through 2 PA 120.3's, a CPU block, nb block and FC gpu block. It did it without a problem.
I am glad you're enjoying the case.
Two New "Toys" (Pics: 1024x768) AmuseMe Off Topic 15 April 7, 2010 11:38 PM
Unauthorized Playing With Toys? fefox Off Topic 1 June 19, 2009 04:33 PM
One of my new toys mklym Mobile Computing 5 January 16, 2009 10:41 PM
Eagle Eye's new toys Eagle Eye Case Mods, Worklog & Gallery 19 November 6, 2008 09:38 AM
Some questions about F@H qwerty HardwareCanucks F@H Team 4 October 16, 2007 06:45 PM
