Old December 4, 2007, 04:47 PM
Cptn Vortex's Avatar
Default Best loop configuration?
Hey all, I am adding some extra parts to my current loop. Just thinking of how best to arrange it. So Far, I have this:
Res-pump-chipset-VGA-RAD-CPU-RES
I am adding a second dual Swiftech RAD, the one with the RES built in, going to hang it off the back with a RADbox. Currently I have a single Swiftech Dual120mm RAD in the top of my TJ09. What would the best config be? I don't know which RAD will provide the best cooling, as the one in the top gets fed warm air from the mobo, but the one on the back will get fed warm air from the powesupply.... Which one should I have cooling my CPU?
Should it go:
RESrad-Pump-VGA-VGA-Chipset-RAD-CPU-RESrad?
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old December 4, 2007, 07:27 PM
3.0charlie's Avatar
Originally Posted by Cptn Vortex View Post
Should it go:
This is one aspect of those new resrads I don't like. A typical loop would be res - pump - rad - cpu. This allows the pump maximum liquid flow from the res, and still provide the coolest liquid to the cpu.
Now with your parts you could also go for:
resrad - pump - cpu - NB - rad - vga - vga - resrad.
John
Hydro-Quebec is salivating...
Old December 4, 2007, 10:19 PM
Well, thanks! I guess I will map it all out tomorrow and see what the best and easiest way to route all the tubing will be. Should look nice once it's all done!
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old December 4, 2007, 11:36 PM
JayDee
Guest
Posts: n/a
I think this would be a good loop config (if I understand your components correctly)
I'd mount the rez-rad as high as possible to get the rez portion as high as possible in your lopp and to get the barbs as high as possible to have access to your GPU blocks.
Have fun :)
Old December 5, 2007, 12:08 AM
"Quote This..."
good idea JD!
A rad between each unit. Cool the liquid before the cpu/nb and again before the gpu's.
I like it.
Old December 5, 2007, 06:16 AM
3.0charlie's Avatar
Yup, another option. But I would rather use the external rad to cool the CPU / NB, and use the internal rad to cool both cards. If that's possible with the component locations.
Old December 5, 2007, 11:03 AM
I like it! My top RAD is already in place, so I wont be swapping the location, but that was kindof what I had in mind. I'll show you when I have it all together!
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old December 5, 2007, 11:16 AM
I think this may be the best way to do it, as the case has holes already on the back of the case for watercooling. It would also use the shortest runs of cables I think.
By the way, we rule at Paint!
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old December 5, 2007, 11:23 AM
3.0charlie's Avatar
You're putting the heat load of both vga cards and the NB on the internal rad, which then will rely on the hotter internal air to cool the cpu. I would try something else - but you are getting the pattern.
John
Old December 5, 2007, 11:38 AM
Hmm...I see what you mean. Back to the drawing table!
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Ram Water Cooling loop Shredder Water Cooling 5 January 24, 2008 09:55 PM
Fan loop SpateD Water Cooling 6 January 21, 2008 07:30 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
Need Help With This Configuration Rapid-X CPU's and Motherboards 10 May 31, 2007 05:11 AM
