Old August 20, 2010, 06:46 PM
Post Need help with noise etc..
Recently i got a swiftech MCR drive 320, it's a radiator with integrated pump & res.
picture of my dusty rig here with rad on radbox at the back
Now the problem is noise, the fans are scythe gentle typhoons 1150rpm. They are pretty silent, the noisiest thing seems to be the pump which is an MCP 350. it has a highish pitch noise to it and it is making a hum which comes and goes, so in all those noises are a bit irritating to me and i was hoping it was going to be quieter than it is. if you are wondering why i bought it, it was mainly for ease of setup & obviously hoping for a quiet system.
Another problem is the cabling, if i move them even a bit then something rattles/buzzes until i move the wires again. also for some reason, the waterblock would not mount one of the other possible ways, some of the bolts would just get stuck while trying to screw them in.
I also discovered i somehow managed to scuff/dent the block as there are markings just around the outside of where the cpu would be actually i think right where it goes on the cpu socket.
Anyway, is there anything i can do about the noise?.
Old August 21, 2010, 08:15 AM
Dazmode's Avatar
Try to put pump on anti-vibration pad.
Orange Build: Final Video
HTPC Build: Final Video
Old August 21, 2010, 09:32 AM
MpG's Avatar
MpG MpG is offline
It's hard to say for sure (noises are hard to describe), but your pump noise sounds a lot like what you get if the pump has a solid contact with the case. Given that you have an MCR Drive, your options are kind of limited, but you might consider detaching the assembly from the back of the case, just to see if the noise changes any.
Also, while I know this is just a picture, your tach wire from the pump looks like it's catching in one of the case fans. Wouldn't surprise me if that was the source of your rattling/buzzing when the cables are moved.
Old August 22, 2010, 08:08 AM
KaptCrunch's Avatar
the pump is incorperated into rad so would need these to mount rad
sounds if got a bad rotor or pump was dropped knocking the balance media outta place
or can be case rivettes loose would need to buck them tighter
+1 Mpg good call on tack wire
Old August 22, 2010, 02:23 PM
Hi, those fans are not running. at least not yet, i left them off. I would not let a cable touch the fan like that and turn it on unless it was by accident of course, i think the buzzing is to do with the top fan attached to the radbox, moving it slightly makes a tick/buzz noise.. not 100% but i think it is.
The thing isn't really loud, it just has annoying noises to it. it's not constant. Like the humming that comes and goes and the impeller (sounds like) noises seem to be up and down. if it wasn't for them i would be much happier, it's just irritating.
Old August 22, 2010, 03:27 PM
KaptCrunch's Avatar
drain loop
open pump,WB an check if is alright
NOTE:be careful of 0-ring's and pump impeller is held by STRONG magnetic field, so when time to install again careful not to let it smack back in place (hold back) for not to chip/DAMAGE the cermic ball or rotor bearing surface
Old August 24, 2010, 08:21 AM
Rison's Avatar
perhaps get some 120mm fan gaskets to separate your fans from your rad a little better. I've seen some rubber ones that are realitively "thin" - like the ones that come with TFC rads.
Do what Daz said.
And buy some small, black tie-wraps for your cables. :)
I'll learn to manage my anger, when people learn to manage their stupid.
120v outlet filter for noise, such a thing? (popping noise from speakers) On2wheels Troubleshooting 3 June 20, 2010 08:06 PM
noise filter help needed mo' power Networking 8 January 11, 2010 04:31 AM
noise canceling microphone CTA Audio 3 August 31, 2009 03:40 PM
Noise in speakers from onboard? Skyllz Audio 6 August 27, 2009 04:12 AM
Reservoir noise matsta31 Water Cooling 17 January 26, 2009 07:28 PM
