Old August 17, 2010, 06:37 AM
TokeR's Avatar
Default I think I set my loop up wrong...
Hey everyone, I was just wondering if some of more experienced water coolers could tell me if my loops set up wrong or not.
I made a lovely picture for you to examine:
I tried to show you the way it's going but I will also spell it out as these things can sometimes be pretty hard to explain..
Starting at the: Radiator > Then the Pump > then the Reservoir > then the CPU block then back to the Radiator.
I just got the CPU block today and stupidly rushed into it.. and now I have all the liquid in there I really don't want to take it apart.. so...
How important is it to have the right In/Out pipe on the CPU block?
and How much will it improve cooling?
Thanks guys.
Old August 17, 2010, 06:41 AM
gingerbee's Avatar
wrong . pump must draw water/fluid from res. not into you need to change that for sure the way you had it first time was right.
Old August 17, 2010, 06:43 AM
TokeR's Avatar
Could you have another look at the image just incase, I re uploaded it just before as the arrows of the flow were pointing the wrong way
Old August 17, 2010, 07:18 AM
gingerbee's Avatar
switch the order of pump and res. just put the res before the pump and your good to go.
Old August 17, 2010, 07:19 AM
TokeR's Avatar
alright thanks man.
gingerbee's Avatar
rad--res--pump--cpu block. that order
edit nice setup pics??
Old August 17, 2010, 08:05 AM
TokeR's Avatar
Wow, this whole task would have been 100% easier if I could have just switched the direction of the flow.. lol wonder if there are PC wc pumps out there you can do that with..
Old August 17, 2010, 08:06 AM
TokeR's Avatar
Soooon when everything is looking nice thanks for your help mate.
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
SSD set to IDE boots allot faster the set to AHCI Shadowmeph Storage 9 May 27, 2010 04:55 PM
Is something wrong howpet HardwareCanucks F@H Team 16 May 4, 2010 08:57 AM
Something's wrong with my PC Spikemaul Troubleshooting 2 April 19, 2010 11:32 PM
What went wrong? punk_zappa Troubleshooting 11 June 20, 2009 10:31 AM
