Old August 16, 2010, 08:45 PM
Default copper + nickel = trouble?
soo what happens when u have a copper cpu block and a nickel mb block in the same loop? ive been told it makes a battery and all sorts of bad things will happen. true?
Old August 16, 2010, 08:57 PM
Dazmode's Avatar
complete bull. Do not worry.
Orange Build: Final Video
HTPC Build: Final Video
Old August 16, 2010, 09:34 PM
Arinoth's Avatar
To my knowledge water used in water cooling is de-ionized water/coolant. It being de-ionized coolant there should be no risk, it if was standard water (aka ionized water) you'd potentially have issues
Here I am: here I remain
Old August 16, 2010, 09:59 PM
Dazmode's Avatar
Scroll down to read.
Old August 17, 2010, 06:03 AM
gingerbee's Avatar
bingo
Old August 17, 2010, 06:52 AM
JD JD is offline
And it's likely it's only nickel plated, underneath is still copper. Nickel plating just helps prevent copper from corroding/changing colour.
Don't think I've seen any pure nickel blocks. Silver yes, but not nickel.
Old August 17, 2010, 07:36 AM
awsome thats what i was hopeing everyone would say. thanks alot guys
Old August 18, 2010, 08:13 AM
AmuseMe's Avatar
Aluminum and copper is something you do not want to mix. Copper and nickel is fine.
Old August 18, 2010, 09:07 AM
Jackquelegs's Avatar
Google: Galvanic Corrosion
Galvanic and Corrosion Compatibility Dissimilar Metal Corrosion - Engineers Edge
As you can see Aluminum is -1.66v at standard reduction potential, that means it's VERY easily reduced. When mixing with copper in an aqueous (and ionic) solution, aluminum ions will precipitate into metal (reduction), and solid copper will become copper ions (oxidation).
Overall voltage of the Cu/Al cell will be +0.34 - (-1.66) = around +2.00v (which means it's spontaneous)
If you mix Cu with Ni the resulting voltage will be +0.34 -(-0.25) = around +0.59v (spontaneous but it's not very strong since Cu and Ni are very similar)
/rant
Iapetos
Zephyranthes
Old August 18, 2010, 09:10 AM
Arinoth's Avatar
Like i said, water cooling coolan is de-ionized solution so it shouldnt be an issue. Thanks for bringing out the science (i was too lazy too)
installing a Ek Water Blocks EK-FC4890 CF Nickel Full Cover Radeon HD 4890 GPU Block bc_tileguy Water Cooling 7 July 7, 2009 03:59 PM
[FS] Danger Den Tieton Nickel Plated - GTX 280/260 Waterblock zlojack Buy/Sell & Trade 13 January 23, 2009 08:41 AM
Question about Noctua NH U12P SE 1366 (Nickel plate, installing both fans issue) appplejack Air Cooling 5 January 13, 2009 01:44 PM
[WTB] Copper NB or mosfet HS Varroa Buy/Sell & Trade 3 November 30, 2008 07:32 PM
TRUE Copper Heatsink! Killswitch Air Cooling 4 October 26, 2008 11:48 AM
