<~----> Pump/Res mounting ideas - Hardware Canucks
Old August 16, 2010, 10:08 AM
Default Pump/Res mounting ideas
Hi Guys,
This is a link to my previous setup I had.
http://www.hardwarecanucks.com/forum...mg_0016-1-.jpg
Hardware is the same, I need help re-positioning the Res, where it is right now, it a lot harder taking the video card out. I was first thinking of putting the res in one of the drive bays, and using the fill-port hole on the HAF. It's not shown in the pic, but I had another piece of tubing attached to the bottom of the res, with the fill-port attached to that tubing for draining purposes.
Does that loop look right, including the way the cpu block is mounted and inlet/outlet. It's an Apogee GTZ
Old August 16, 2010, 01:36 PM
dustin1706's Avatar
Can you put it right beside the pump? Just put something under it so that the pump inlet is even with the res port and then just use a very short piece of tubing?
I can't see anything wrong with the setup.
Old August 20, 2010, 01:11 PM
Trial Member
Perhaps you could place it on the 120mm fan using brackets?
Old August 20, 2010, 01:20 PM
chrisk's Avatar
Folding Captain
Here is my similar setup in a Haf:
Fold for team #54196
Old August 20, 2010, 03:34 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeah I would put it just above the pump like chris
Old August 20, 2010, 04:29 PM
JayDeeHobbit's Avatar
Looks like you have room up top - that's where I put it in my Armor case and it worked great for me.
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
Old August 29, 2010, 11:27 AM
Jokester's Avatar
His rad is up top, I would get an ek res and do similar setup as Chris did. Or is there enough room in the drive bay ?
Techead in mind, body and soul
Lian Dream: i7 2600k @ 5.1Ghz, Asus Maximus IV Gene-z, MSI N580GTX Twin Frozr II,8GB 2x4GB Mushkin Ridgeback, Crucial M4 128GB x2, Plextor PX-755SA, Seasonic 750, Lian-li
HTPC: E5300@3.6ghz, Asus P5Q Pro Turbo, Gigabyte 7600GT, Mushkin redline 1GBx2, 2x 500gb Maxtor Raid 1, 300gb Seagate, 74gb Raptor, PC P&C 510, Silverstone LC16m
Old August 30, 2010, 06:05 PM
bkh2's Avatar
If you flip the rad around, it might work out better. Here's how I set mine up:
http://www.sfu.ca/~bkh2/Comp/P8300091.JPG
http://www.sfu.ca/~bkh2/Comp/P8300094.JPG
http://www.sfu.ca/~bkh2/Comp/P8300095.JPG
From the first pic, you can kind of see that the tube quite long and wraps around the fan. This allows a lot of excess tubing so the graphic card can be taken out easily. I actually recently changed my loop to this configuration because I had trouble taking out/adding graphic cards. The res is attached by one screw, through the motherboard. In fact, the threading on the screws that come with the reservoir match the threading in the motherboard, so no modification is required.
Also, the pump isn't attached in any way; it's free floating. This isolates the pump from everything so it's quite quiet. In addition, the pump can be bent towards you (out of page) which allows even more slack for the tube in front of the graphic card. This configuration only occupies the top 5.25 bay, leaving the 5 others completely free.
Edit: Just for reference, this was my old configuration: http://www.sfu.ca/~bkh2/Comp/P2150136.JPG
Notice how close the tube going from the res to pump is to the graphic card. This issue is also minimized by having a free floating pump.
Old August 31, 2010, 05:30 AM
Rison's Avatar
what ChrisK posted - I think I stole his idea for my loop to. Well.. not "stole" so much "borrowed" and give him credit for inspiring the setup.
It's the cleanest I can think of, and makes it easy to watercool your GPU in the future.
I'll learn to manage my anger, when people learn to manage their stupid.
First time WC setup! Rad mounting ideas? tragd Water Cooling 11 August 17, 2010 02:57 PM
Where to buy XSPC 5.25 Bay Dual Res, Dual DDC Pump Kartner Water Cooling 11 July 1, 2010 09:14 AM
[WTB] Pump/Res/Rad kruzn4evr Buy/Sell & Trade 4 April 23, 2010 08:30 AM
[WTB] WC Gear Rad / pump / res / cpu water block anabioz Buy/Sell & Trade 8 December 17, 2009 03:33 PM
[WTB] WC parts (pump, res, tubing, chipset block and 4850 compatible GPU block) donimo Buy/Sell & Trade 5 February 2, 2009 11:53 AM
