  #41 (permalink)
Old August 20, 2010, 09:50 PM
Its an unfair comparison, H70("Exhaust in" setup) vs Air Heatsink. Reason being temperature reading does not take into consideration, comparing raise in temperature in components such as motherboard, ram, video card.
Air Heatsink pushes hot air to places where its easily exhaust out(removed) with high speed eg. 1900rpm: back or top of casing.
But H70 pushes hot air into case with high speed eg. 2000rpm making it(hot air) very difficult to be exhaust, increasing other component temperatures.
eg. i7 920@3.8ghz difference btw H70 & Venomous ~10C, however Air Heatsink does its best to push hot air out(back/top), H70 does its best to push hot air in(middle/front) & take in account extra 10C more dump inside, while CPU chills, motherboard, ram, video card sweats. The better H70 cools, the more the other sweats.
Simple solution (Exhaust out) setup instead. But you'll need more/fast intake chassis fans to provide air for H70, that also improves temperature readings for Air Heatsink. Which is why i said that its an unfair comparison between H70 vs Air Heatsink.
  #42 (permalink)
Old August 21, 2010, 04:13 AM
MonsterSound's Avatar
Default 2c
Originally Posted by JohnHenery View Post
The reason they needed to make the pump smaller was because of the thickness of the rad plus 2 fans...
I see your point, but in my imaginary H70, I would have used the single width rad like the H50 has rather than the bulky double width one. Just with an increase in the flow rate and the tubing diameter. My imaginary H70 description was obviously lacking. If bulk isn't an issue, I suspect a NH-D14 (or how about Megahalems/Fenrir) might out-cool the H70 (med fan settings for livable sound level) but I haven't found a comparison yet.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
  #43 (permalink)
Old August 27, 2010, 06:45 PM
Default I was going to cheap out ... but...
I was going to cheap out ... considering h50, h70 or coolit eco, but ncix had a new sale and with rebate the price was more acceptable to me... I bit the bullet and have a new Corsair H70 on the way...
Intel Core i5-750 2.66Ghz @ 4Ghz, ASUS P7P55D-E Pro, 4GB G.SKILL Ripjaws cas7, WDC 1Tb WD1001FALS, WDC 640Gb WD6400AAKS, OCZ Vertex 2 Extended Sandforce 60GB, GIGABYTE Radeon HD 7950 3GB 384-bit GDDR5, Corsair Hydro H70, LG GH24NS50 DVD 24x Burner, Antec Eleven Hundred, Antec TruePower New TP-750 750W, Microsoft Windows 7 Ultimate x64
http://i571.photobucket.com/albums/s...osmond/1-1.jpg
http://i571.photobucket.com/albums/s...benchmarks.jpg
  #44 (permalink)
Old August 28, 2010, 04:21 PM
I bought an H70 yesterday locally @ Memory Express after reading a review on it in the latest Maximum PC issue.
I read the instructions and it says to install fans as an intake. But my Raven RV01 case has a single 120mm as an exhaust. The MaxPC article recommended to install as exhaust although their sentence wording is a bit misleading. Browsing the web and various forums (Corsair, Overclockers, etc.) reveal pros & cons for each method. I was thinking of utilizing the Raven's 120mm fan along with the H70 radiator and single H70 fan if I can. Otherwise I'll remove the original fan and install both Corsair fans. Either way it will be set up to exhaust the H70 air.
Thoughts?
System Spec Peripherals: NZXT Kraken X42 CPU cooler | Zalman MFC3 fan controller | Steelseries Apex M800 kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakersDrobo FS 6.5TB Synology DS1515+ 15TB
Laptops: Asus G74SX-DH71 | Asus G752VY
Surface Pro 4 Core i7/256GB
  #45 (permalink)
Old August 28, 2010, 06:56 PM
BootlegUsher's Avatar
Absolutely install your H70 as an exhaust on the Raven. The whole airflow system of your case depends on air shooting out of that opening, if you turned it into an intake you would just create a mess or turbulance in your case.
I would only follow Corsairs reccommendation if I had a case with large top fans to immediately suck the air out.
  #46 (permalink)
Old August 28, 2010, 08:21 PM
^Agreed, B'Usher. I'll likely be installing it this w/e and will post results after it's up and running.
Cheers & happy cooling!
  #47 (permalink)
Old August 29, 2010, 09:59 AM
I got the H70 installed last night. Took about 90 minutes from removal of the Zalman cpu fan to boot up with the new cooler. Installation of the H70 was much easier than I thought it would be inside the Raven. I initially did try keeping the stock Silverstone 120mm exhaust fan in place and attach the radiator to that with one of the supplied Corsair fans. However when I ran the system this way I realized that the max rated speed of the Silverstone fan is only 950rpm. So I ended up removing that fan and used both Corsair H70 fans to achieve the rated 1600/2000 rpm ratings. At max settings these fans are indeed loud with an annoying whining pitch. At 1600rpm the whine goes away and the flow noise is minimal. I've got the fans connected to the fan controller so I can dial in the speed without using the supplied resistor cables. However, I'm already looking at getting two replacement fans that can supply the required max speed and low dB's. Also, I wouldn't mind a couple of fans that have LEDs to provide some bling inside the dark case.
As for preliminary temps, I wasn't expecting much of a change and that's exactly what I got. In fact, idle temps across all four cores are reading roughly the same or 1~2 degrees higher than the Zalman CNPS9700 I had in there before. I still have my Core i5 750 oc'd to 3.4GHz with the H70 so it's not too bad for being straight out of the box. Perhaps once the thermal paste sets the temps will improve. Or when I get better fans. I haven't bothered stress testing yet until the system settles. Overall the H70 was a fun install and is 'cool' to see inside the case.
  #48 (permalink)
Old August 29, 2010, 02:36 PM
Dazmode's Avatar
Kind of sad result, Go WC and get worse
Orange Build: Final Video
HTPC Build: Final Video
  #49 (permalink)
Old August 29, 2010, 03:21 PM
Idle temps are worthless. Those readings don't mean anything.
  #50 (permalink)
Old August 31, 2010, 09:45 AM
Correct! It was just my initial impression after installing said cooler.
In my quest of getting different fans in pursuit of quieter performance...
I've come across some 120mm 2000rpm fans with *reported* dBa's of around 19~26 by Scythe, Noctua, CoolerMaster, and Silverstone. Any suggestions? Do I need to try to stick to fan speed (RPM) criteria or can I go with something slower yet produces the same CFM as the Corsair units?
I've also come across a couple of articles where the top exhaust/pull fan is mounted outside the case. I may give this a try as well.
Corsair Hydro Series H70 CPU Cooler FiXT Press Releases & Tech News 42 August 10, 2010 05:01 PM
Corsair Launches Hydro Series H70 CPU Cooler FiXT Press Releases & Tech News 19 August 8, 2010 12:48 PM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
