Old August 16, 2010, 05:34 AM
Arinoth's Avatar
Originally Posted by thorn View Post
Out of curiosity why was the H70 not tested with 2 scythe s-flex fans?
definitely an interesting cooler and has got me thinking maybe going this way for my next rig as this looks to be a relatively painless way to get into water cooling.
Originally Posted by Zero82z View Post
This is not "getting into water cooling". Using a self-contained system like this is no more involved than using a standard heatsink and fan setup. If you really want to get into water cooling, then you need to build your own loop.
That is exactly the point. It is supposed to be for people who don't have a clue about setting up a watercooling rig (such as myself right now) but still want the potential benefits of running your system on water and supposedly quieter and cooler.
Here I am: here I remain
Old August 16, 2010, 05:43 AM
Delavan's Avatar
LOL. I was thinking along these lines also. Would it work fine with 2 X 120MM Noctuas?
I know HWC reviewers are often swapping fans on HSF, for some custom testing with alternate fan solutions...
would be really nice to know how this H70 functions with "P" rated Noctuas.
If it's decent, I'm IN on my next built!
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old August 16, 2010, 05:52 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
The dual fan results are always run with NF-P12 fans. We cannot account for every eventuality in the reviews unfortunately.
MrDiaz's Avatar
There is a typo on the graphics, says "Inisde Case"
-- Viva Canada! --
Old August 16, 2010, 06:54 AM
Well I was going to point out the whole water thing but others have beat me to it.
Also I would imagine a custom water cooling loop would be more expensive than this.
Old August 16, 2010, 08:48 AM
Smoothie's Avatar
I would love to see a comparison between the H70 with the Megahalems and other high end Air coolers using 3000 RPM fans.
Old August 16, 2010, 09:19 AM
Delavan's Avatar
OUCH!
Sry Sky, it's what I got for jumping to conclusions too quick. You folks indeed tested with NF-P12!
Good job as always!
Old August 16, 2010, 10:03 AM
fishingfanatic's Avatar
Smile Water Cooling
Great review as always SKY! Ok, if you want to say you have some water cooling then technically this is such. However, the real WC pros know this is nothing more than a sales gimmick. It seems the results work quite well with the fans maxed out. As pointed out by another member, too loud imho. If you swap fans, it brings the cost up, unless like me you already have a few kicking around.
Bottom line I think I'll stick to air cooling for now. Being a tradesman, I would consider installing a good centrifugal pump setup if going that route with braided lines and compression fittings to minimize leakage. Might look good too!
  #19 (permalink)
Old August 16, 2010, 10:19 AM
Originally Posted by SKYMTL View Post
IMO, the reason it is a first step is BECAUSE it isn't installation any more involved than some of the better heatsinks on the market.
In addition, many people are simply afraid of having water or coolant flowing through their cases. Having something like the H70, ECO, etc shows them that water cooling can bring higher performance without the worry of leakage.
Last I checked though, there was fluid passing through this unit so it IS water cooling...
Yeah, it technically uses water as a coolant, but it isn't significantly better than a good heatsink, and it's a lot more expensive. It is also not a real introduction into water cooling, because setting up an actual loop yourself is a completely different experience. It doesn't give you a taste of what water cooling is really like other than slightly better performance than air.
Well, if you look around for used components then you could probably put together a CPU-only loop for a similar price, but a full loop would indeed be better than this. However, on the flip side, a good heatsink is also much less expensive and doesn't perform that much worse. The practical benefits of a system like this are dubious since you generally won't see any improvement in overclocking potential because the temperature difference compared to high-end air just isn't that big.
I'm not saying it's a bad cooler, but I definitely don't think it's worth the price compared to air cooling.
  #20 (permalink)
Old August 16, 2010, 11:18 AM
yea, not liking the noise levels.. guess i'll wait for the HR02 to show up in stores.
Corsair Hydro Series H70 CPU Cooler FiXT Press Releases & Tech News 42 August 10, 2010 05:01 PM
Corsair Launches Hydro Series H70 CPU Cooler FiXT Press Releases & Tech News 19 August 8, 2010 12:48 PM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
