Old August 14, 2010, 11:17 PM
AmuseMe's Avatar
Lowfat, I love you, and you are practically a mod here in my eyes, but Skinny is a liar and a cheater. His reviews are B.S.ed so he gets more free stuff.
You are going to want a higher RPM fan for the MCR series by swiftech. They have a denser FPI than the most common radiators, so the extra CFM would be helpful - this in turn makes more noise though.
Old August 15, 2010, 05:10 AM
MpG's Avatar
MpG MpG is offline
If you're referring to the OC competition, that's one thing. But if Skinnie was fudging watercooling results, he did a horrible job at it - very little distinction between the various radiator brands for the most part, and the brand with probably the highest marketing budget (Feser) actually does a little worse for a lot of the scale. And the GTX480 blocks he reviewed - I'd venture that took way too long for an undertable sponsor to accept.
Anyway, for what it's worth, I'm currently cooling an i7 920 @ 4.0GHz and a GTX280 on just a dual MCR radiator, with Push-pull Scythe fans at about 800rpm, and no troubles at all - the MCR rads are just as capable as their competitors. They have a slightly higher fin density, but they offset it with a thinner core. The one area that you do give up something is fluid restriction - while still much less restrictive than any water block, they're quite a bit more restrictive than many other radiators.
Old August 15, 2010, 07:42 AM
gingerbee's Avatar
lowfat said what needed to be said and i will leave it at that. swiftech rads are just fine
Old August 15, 2010, 10:24 AM
JD JD is offline
Well just for reference, I have the HWLabs SR-1 360 w/ 1450RPM Gentle Typhoons. Block wise, I have a Heatkiller 3.0 Nickel Plated (from Daz) on my i7 920 @ 4.2GHz, ~1.3V along with the HD5870 with EK fullcover acetal/nickel. My CPU under Prime95 gets up around 65C (75C if I push 1.4V) and the GPU stays rather chilly, typically under 40C at stock clocks/voltage.
Old August 15, 2010, 11:43 AM
gingerbee's Avatar
folks ambient really matters when telling someone about your cooling setup. water even more so.
Old August 15, 2010, 02:29 PM
JD JD is offline
I personally don't find my ambient changes things much. My room is anywhere from 20C to 24C though.
Old August 15, 2010, 03:41 PM
just gonna throw this out there , u could always do a switech rad sandwich and buy another swiftech 360 rad to hang off the back as well if you are concernd about temps. that way u could buy your buddys rad/ fan setup for cheap test it out and if its alittle to toasty for your likings u can sandwich it pretty easily for better temps and overall cheapness. just a thought
Old August 15, 2010, 04:27 PM
gingerbee's Avatar
key point your ambient temp range does not change enough and if your pressure stay the same it won't that much. where i am pressure can change fast and a lot and so can temps.
like today it went from 24 to 33 in just over an hour+ so ya when it comes down to it ambient matters when telling someone about your cooling loop. i am running at stock speeds for the summer and my temps never go over 55c. but in winter i can run at 4.0ghz at almost the same temps. ambient always matters.
like i get worse temps on my venomous why .. because it's almost 40+c in my living room.
  #19 (permalink)
Old August 15, 2010, 04:30 PM
@jdrom - Good to hear, and those Scythe's are dead quiet aren't they?
@gomer - I read that the QP (pass through rads) didn't really help much unless you had high CFM fans (2000rpm+) I have considered it and I still am, but I think what others have said about surface area matters the most. If I do have to get a different rad, it'll be a quad one likely. My ambient temps are pretty good, probably 22-23C in the summer and 15-20C in the winter. My basement is cold if there's no PC on in the room :P
Yeah ambient will play a factor, especially since my rad will be always getting fresh air. It'll be interesting to see how much of a factor it plays.
  #20 (permalink)
Old August 15, 2010, 05:56 PM
JD JD is offline
You ought to get some AC then! My room is 20-24C all year round, regardless of what it's like outside. It starts out at 20C (sometimes 18-19C) in the mornings, then if I'm gaming away all evening, it gets up to 24C by the time I finish playing. In the winter though, I can get up to 26C or so with gaming and the furnace.
Never had such a quiet fan at 12V honestly. Noctua P12s are loud in comparison IMO (as I have like 4 of them around)
As in outdoor air? Not sure how wise that is in the summer... Definitely wouldn't want to be using 30-40C air. Winter would obviously be ideal though.
Sufficient Power fishingfanatic New Builds 4 March 14, 2010 03:23 PM
GPU L/C question: MCR220 sufficient? Dead Things Water Cooling 19 October 28, 2009 07:46 AM
Is my PSU sufficient? bazookaworm Power Supplies 6 November 30, 2008 02:42 PM
NVIDIA system sentintel reporting insufficient power? Mibs Video Cards 4 March 14, 2008 04:16 AM
Is NVIDIA 7xxx sufficient for... Mr. Cipher Video Cards 9 February 7, 2008 10:34 AM
