Old August 12, 2010, 01:55 PM
Pax Pax is offline
Default Upgrading from Swiftech H20-220 Apex Ultima+
I bought the watercooling kit mentioned in the title a couple of years ago, and it's been running great for me, but I'm planning on upgrading my computer to an i7/gtx460 setup, and figured I may as well upgrade my wc setup as well.
The kit I bought came with:
Apogee GTZ
MCRES-Micro rev2
MCP655-B pump
MCR220 rad
MCW60 (universal vga cooler)
MCW30 (universal chipset cooler)
I've already swapped out the fittings it came with and the tubing as well. I'm wondering what the weak points of this setup are? I'm assuming a better/thicker rad would help out, and I dont think the mcw60 will work with any newer graphics cards, so I'll probably just take it out of the loop for now so I don't need to drop $120 on a full cover block.
Current setup is in a HAF932 (with a top-mounted rad).
Any input on what I can do to upgrade this (if it's even worth it...I don't think I'm going to spend $100 for a degree or two) would be appreciated.
Old August 12, 2010, 02:02 PM
sswilson's Avatar
Any upgrades you do to that kit will only provide incremental performance benefits. What are you running for fans? Those might actually be the best bang-for-buck upgrade if you're looking to spend a little cash.
Old August 12, 2010, 06:14 PM
Dazmode's Avatar
imho, you are looking for about 5c improvement with latest models CPU block. Your bigger problem is MCR220 which may be noy enough rad for your CPU/GPu combo.
Orange Build: Final Video
HTPC Build: Final Video
Old August 12, 2010, 06:56 PM
+1 to Daz, I was also going to suggest a different rad, a triple rad you would want, and stay away from Swiftech plz.. Feser, HW Labs and Thermochill make awesome rads.. a Feser 360 is a beast..
Old August 12, 2010, 07:21 PM
bottle's Avatar
Originally Posted by miggs78 View Post
+1 to Daz, I was also going to suggest a different rad, a triple rad you would want, and stay away from Swiftech plz.. Feser, HW Labs and Primochill make awesome rads.. a Feser 360 is a beast..
Hey! Nothing wrong with Swiftech Rads, they may be a bit denser and sometimes have bent fins, but for the price, they can't be beat.
Lowest price I saw for the MCR320 was $40, nearly half the price of any Feser or HW triple rad.
Also last time I checked, Primochill didn't make rads! Do they? Or maybe you're thinking Thermochill.
Old August 12, 2010, 07:32 PM
Also last time I checked, Thermochill didn't make rads! Do they? Or maybe you're thinking Thermochill.
Indeed, for the price they are darn cheap, but.. think about it, a Feser rad is twice as thick as a Swiftech, I bet you a Feser dual rad can performance close to a triple, so.. the Feser triple will cool a lot better.
And who said Primochill, I didn't.. Ok I did, I edited my post
Old August 14, 2010, 11:12 PM
AmuseMe's Avatar
I like my HWL SR-1 series thank you very much :D
Old August 15, 2010, 07:34 AM
gingerbee's Avatar
quote facts about rads. the only reason not to buy the cheaper swiftech is looks that's it period.
edit swiftech/car rads and oil coolers for me
Old August 18, 2010, 08:09 AM
AmuseMe's Avatar
Originally Posted by gingerbee View Post
will some of you learn something about rads before you open your mouths. the only reason not to buy the cheaper swiftech is looks that's it period.
EDITL I don't need to be ranting about how much I don't like Swiftech online, it's just sad lol. I'll stick with not liking Swiftech, and if others like them - fine.
Old August 18, 2010, 09:13 AM
Pax Pax is offline
Thanks for the input everyone. I'll probably be upgrading the rad and fans. I've got 4 Gelid Wing12's kicking around I can throw in. I'll see if I can find a used rad on the bst soon.
Antec 1200 case and the swiftech ultima+ nasrott Water Cooling 4 June 22, 2009 06:34 PM
Swiftech H20-120 Soultribunal Water Cooling 5 December 12, 2008 06:10 PM
WTB:Swiftech H20-220 Compact Ken_C Buy/Sell & Trade 3 November 4, 2008 08:59 PM
Adding a second duall rad to the h20 220 compact? frosty Water Cooling 7 July 6, 2008 11:30 AM
Help with Swiftech H20-120 kit Varroa Water Cooling 19 January 4, 2008 09:43 AM
