Without the nozzle kit, the Fuzion is much less restrictive, but I'd expect the GTZ to be worth a degree or two. Not a huge difference, though.
Nozzle-wise, I'm not sure any of them would be all that good. The core layout on the 1055T is pretty spread out, which makes the circular nozzles less effective, and the layout isn't linear, which makes the quad-nozzle less effective. The only part of that nozzle package I would bother using is the o-ring that blocks off the flow bypass.
__________________ i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133 |
