Old August 10, 2010, 06:31 PM
SugarJ's Avatar
In my experience, push/pull>push>pull. Most fans are better pushing air through the rad than trying to pull it through. This can change with rad density and fan design though.
In my loop (feser 360, Heatkiller, EK GPU, 655 pump, Scythe S-Flex G fans) there was a difference in max core temp of about 5 degrees.
Old August 10, 2010, 10:59 PM
Jackquelegs's Avatar
IIRC push or pull do not make that significant of a different in temps. There's going to be a change of ~1 C maximum.
In my experience pull is the better choice because it actually creates a negative pressure zone behind it to pull air through that minimizes the fan's "dead zone".
However when it comes to reality, it really doesn't matter that much
Iapetos
Zephyranthes
Old August 11, 2010, 05:59 AM
JD JD is offline
+1 typically why most suggest pull. I've ran mine in pull since day one.
Though I would of suggested you bought a bayres that supports a direct pump connection. Would of saved you space and simplified tubing.
Old August 11, 2010, 08:59 AM
I'll be using S-FLEX fans, so they should be able to pull fairly well, maybe it will come down to wire length to reach my fan controller.
Space is not an issue for the res area.
Now if only my windowed side panel could be back in stock....
Old August 11, 2010, 09:12 AM
Using pull also allows you to use only 1 set of screws to mount the rad Economic
Iapetos
Zephyranthes
Old August 11, 2010, 09:50 AM
+1 to Sugar, I also agree with Jacque..
Although, I've also had more luck pushing air through rad than pulling, usually I position my rads on the exhaust side, like based on the pic you provided, you want your rad to located inside the case, so I would have the fans under the rad pushing air through the rad to outside.. Push/pull would def. work in your case, chances are you aren't going to see much of a difference and you need more fans..
Old August 11, 2010, 01:41 PM
I just flushed the whole system and I can't remember the last time I was this excited about something new!
Anyone adventurous enough to use barbs without clamps? While flushing everything seemed to hold just fine without any zip ties and what not.
Old August 11, 2010, 01:59 PM
Depends on tubing and barb, something like 1/2" tubing and 1/2" barb requires barbs or zip ties, but something. 7/16" tubing goes nuts on 1/2" barbs, you have to cut off the tubing to take it off. 3/8" tubing on 1/2" barbs, I have never tried that.
Did you jinx ur pants in excitement lol.. Watercooling is pron for us.. :D
  #19 (permalink)
Old August 12, 2010, 06:20 PM
Dazmode's Avatar
For mid-rage fans around 1600-1800 rpm - push or pull is the same thing. I use pull myself.
P.S. Thanks for kind words. :)
Orange Build: Final Video
HTPC Build: Final Video
  #20 (permalink)
Old August 14, 2010, 11:11 PM
AmuseMe's Avatar
I only use 3/8" x 5/8" tubing on 1/2" barbs. Also need to cut it off to remove.
Start FAH, Stop FAH, Start FAH, FREEZE! frontier204 Troubleshooting 5 June 23, 2013 09:02 AM
So..where do i start..? emxc2 HardwareCanucks F@H Team 9 September 5, 2009 09:57 PM
A few last questions before I start up... Barber Water Cooling 26 March 23, 2009 10:14 AM
About to start RainMaker New Builds 5 January 16, 2009 01:02 PM
Pc Start up Problem JuggsJr Troubleshooting 5 November 26, 2007 08:04 PM
