Old August 10, 2010, 12:39 AM
Default Adding a 2nd rad and pump - series or independant??
Hi,
Just got a 700D and will be moving my system from a cramped CM690 and so will have lots of room (for a bottomless money pit...lol)
What I'm thinking about is adding a 2nd pump and rad to the current system
Q9450 @ 3.2 with EK Supreme LT
EK-NB
GTX260 SLI w EK-GTX260
PA120.3
case temp blowing into rad 25.9, rad inlet temp 27.2, rad outlet temp 27.0
current loop CPX-Pro => 120.3 => CPU => NB => 260's in parallel => T line => pump
What I'm thinking of doing is this
CPX-Pro => 120.3 => CPU => NB => 2nd CPX-Pro => 120.2 => 260's in parallel => EK Res => pump
or
CPX-Pro => 120.3 => CPU => NB => EK Res => 2nd CPX-Pro => 120.2 => 260's in parallel => pump
or
1st loop CPX-Pro => 120.3 => CPU => NB => EK Res => pump
2nd loop CPX-Pro => 120.2 => 260's in parallel => T line (or could both loops run thru the EK Res??) => pump
Any thought on what would be best? and I know this may be overkill now but an X58 / i7 set is in the cards as my current EVGA 750i FTW doesn't support ACHI for SSDs.
Cheers
Old August 10, 2010, 02:00 AM
MpG's Avatar
MpG MpG is offline
In your position, I'd run the stuff in a single loop. Since both the CPU and GPU are high-heat components, there really isn't any benefit to isolating them in separate loops. Plus, it gives you redundancy in your pumps.
Old August 10, 2010, 11:46 PM
OK, routing wise I think this is going to be best
My question now is do I need to have a res ( would be a T-line )between the NB and the 2nd CPX-Pro?
Old August 11, 2010, 01:18 AM
Jackquelegs's Avatar
Given any thoughts of running them in parallel?
Iapetos
Zephyranthes
Old August 12, 2010, 06:16 PM
Dazmode's Avatar
My vote for one loop. Order doesn't matter, except reservoir before pump.
Orange Build: Final Video
HTPC Build: Final Video
Old August 13, 2010, 04:37 PM
So a T-line before the 2nd CPX-Pro will be fine
What if this T-line was plumbed into the the EK-Res like this
1st CPX-Pro=>120.3=>CPU=>NB=>T-line=>2nd CPX-Pro=>120.2=>GPUs=>EK-Res=>1st CPX-Pro
Would this end up with the 2nd CPX-Pro "pulling" too much out of the EK-Res and no enough from the NB? or would the flow of the entire loop negate any pull by the T-line from the EK-Res?
Old August 13, 2010, 06:00 PM
Originally Posted by TALON View Post
Would this end up with the 2nd CPX-Pro "pulling" too much out of the EK-Res and no enough from the GPU? or would the flow of the entire loop negate any pull by the T-line from the EK-Res?
It's a closed loop, there is no such thing as pull or push by components.
Iapetos
Zephyranthes
Old August 13, 2010, 10:31 PM
MpG's Avatar
MpG MpG is offline
You only need a single reservoir/T-line in your loop. When you're first starting to bleed the system, only run the pump that's immediately in front of the water supply. The water will go through the second pump while you're beginning the bleeding process. Plug in/turn on the second pump once a fair bit of air is out (so that you don't run the second pump while dry).
Old August 14, 2010, 05:00 PM
OK so if I'm understanding this right as long as there is the EK-Res in front of one of the pumps (which would be started first when bleeding) the 2nd pump doesn't need any Res feed as the loop becomes the Res for that pump.
Old August 14, 2010, 05:11 PM
shaw
Guest
Posts: n/a
Correct.
Just bought 2nd hand pump, how do I remove the reservoir Darfyddi Water Cooling 7 May 19, 2010 07:40 AM
[WTB] Pump/Res/Rad kruzn4evr Buy/Sell & Trade 4 April 23, 2010 08:30 AM
Adding pump question bolweval Water Cooling 7 September 23, 2009 11:19 PM
Corsair Adding 256GB Extreme Series SSD FiXT Press Releases & Tech News 0 August 25, 2009 10:36 AM
Adding a second duall rad to the h20 220 compact? frosty Water Cooling 7 July 6, 2008 11:30 AM
