Old August 8, 2010, 11:27 AM
Default Rad damage
Hello guys, I accidentally dropped something on my rad while cleaning, is this considered bad damage, or it should still be effective.
The other side is in mint condition..
Old August 8, 2010, 11:29 AM
Lpfan4ever's Avatar
I only see aesthetic damage. As long as it's not leaking, it's still fine.
Originally Posted by encorp
Code:
<firebane> slightly used
Old August 8, 2010, 11:30 AM
sswilson's Avatar
Assuming that it hasn't pierced a water channel, it's not really that big of a deal when you consider what percentage of the total surface area is affected. If it were mine, I'd use a jewelers' screwdriver in an attempt to straighten them out for best airflow and just carry on from there.
Old August 8, 2010, 11:31 AM
stoanee's Avatar
Is there a hole in it? If not carefully use a small flathead screwdriver or something like that to straighten the bent fins back out. It should have minimal effect on the cooling.
*edit*..ninja'd!
heatware
Old August 8, 2010, 11:35 AM
Looks as if only the fins were damage.
It'll be fine.
Old August 8, 2010, 11:43 AM
lowfat's Avatar
My rads generally are so bruised and bent up. The only real issue it will cause is aesthetics.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 8, 2010, 11:55 AM
stoanee's Avatar
Ya, it looks like you hit a grasshopper in Saskatchewan doing a buck-twenty.
heatware
Old August 8, 2010, 12:15 PM
Spikemaul's Avatar
Some of our grasshoppers here do more damage than that.
Old August 8, 2010, 05:33 PM
AmuseMe's Avatar
+1
Do a quick "blow test". Plug one of the holes of the rad with a stop fitting or your thumb and blow into the other hole really hard and put your tong on it to seal it. If there is no air leaking you air fine.
15 damage...that adds up Arinoth Off Topic 15 July 23, 2010 01:24 PM
Smoke Damage Beermaster Troubleshooting 11 August 11, 2009 09:01 AM
Collateral Damage Alwaysrun Off Topic 12 February 6, 2009 09:19 AM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
how to damage a cpu? magictorch Overclocking, Tweaking and Benchmarking 8 July 28, 2007 08:31 PM
