Old August 5, 2010, 08:06 AM
Default Do I have everything I need for WC loop?
My first watercooling loop :
- triple rad
- CPU block
- GPU block
- pump + top
- reservoir
- tubing
- fans
- fan controller
- fittings ... now by my calculations I'll need 10, did I forget some?
Am I missing anything?
Also my 5870 is the reference design, so it has a backplate ram cooler, can I re-use it with the block instead of buying the EK version?
Really excited and anxious to order!!
http://www.thecomputermadesimple.com | The computer world in plain English!
Old August 5, 2010, 08:13 AM
martin_metal_88's Avatar
Be sure to order 1 or 2 more of each fitting so if you have a bad one or decide to change the loop at the last minut you always have enough. Usefull overtime also for cleaning. You miss some liquid, I hope you were not looking for flat water from the kitchen:P TFC make some good UV or colored coolant.
Edit : youpi! 2600 post!!
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old August 5, 2010, 08:49 AM
sswilson's Avatar
Don't forget to measure twice, cut once when it comes time to working with your tubing. I personally like to cut the tubing a little bit longer than I expect the final product to use so that I have some wriggle room once everthing is together. It's a lot better to trim an inch off than to start over with a fresh piece.
What are you using as clamps for the tubing, and do you have spare mounting screws for the fans?
Old August 5, 2010, 09:41 AM
Sorry forgot to mention the fluid, it's in my cart. The red UV one.
For clamps I was thinking black zip ties. Compression fittings are nice ... but barbs bring the total to 30 ish $ while compression comes up to 100 ish $
Got plenty of screws for the fans.
Old August 5, 2010, 09:45 AM
sswilson's Avatar
Other than the swiftech ones that came with a kit, all I've ever used is zip ties and I've never had an issue with them. I use two/barb, and ensure that both are below the barb seal lip.
Old August 5, 2010, 09:48 AM
Perfect thanks. Do you use the long barbs or the short ones?
Old August 5, 2010, 09:49 AM
sswilson's Avatar
It's best to have a combination of both. I prefer the long ones, but sometimes you need a short one in order to make the loop work properly.
Which barbs are you looking at?
Old August 5, 2010, 10:18 AM
Bitspower ones : 3/8 ID Tubing - Barb - Matt Black 3/8 ID Tubing - Barb - Matt Black [BP-MBWP-C02] - $3.29 : Zen Cart!, The Art of E-commerce
Old August 5, 2010, 11:13 AM
sswilson's Avatar
I'd check to see what other peoples' experience has been with those barbs... the only set of barbs I ever had a problem with were ones with a short thread like those have........
Old August 5, 2010, 12:04 PM
MpG's Avatar
MpG MpG is offline
Haven't had any trouble myself on the odd occasion that I've used BP's 3/8" barbs.
IMO, the bigger issue is what you're screwing them into. The short thread is actually good because it guarantees that the threads won't screw down far enough to obstruct water flow within a block. But if you're screwing into a block that has the threads countersunk slightly for better o-ring retention, you can lose a significant amount of thread grip. Not too much on an issue these days, usually.
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
Help with a new WC loop Master-Spud Water Cooling 8 June 24, 2010 11:19 AM
Will 1 loop be enough? Musabi Water Cooling 14 March 21, 2010 09:33 AM
Loop help Lpfan4ever Water Cooling 12 September 22, 2009 06:22 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
