Old August 2, 2010, 09:48 AM
element291's Avatar
Default quick wc question about fluids
Hey guys, i've had my watercooling setup for about a year and 7 months using clearflex 1/2 tubing, with feserone blue uv premix.
Sure enough the premix has separated over time, and im starting to see cloudy white stuff floating around and hanging off the barbs on my swifttech micro-res.
I was thinking of getting some primochill primoflex pro LRT UV blue tubing and just running distilled to prevent having to re-do my loop every year with the junky premix build up.
I want the blue UV look still, and am open to suggestions on what i could potentially run as tubing, or fluid.
If you think the primoflex lrt is decent, and distilled would be a good way to go, is there anything else i should be adding to the distilled water?
Thanks in advanced for any help guys!
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old August 2, 2010, 10:27 AM
MpG's Avatar
MpG MpG is offline
I'd highly recommend going that route, really. The only thing you give up with coloured tubing is the lack of colour in any clear reservoirs/block tops. The LRT is anti-microbial, and bends well - lots of happy customers with the stuff.
Old August 2, 2010, 12:14 PM
Lpfan4ever's Avatar
Yeah, I'd go with what MPG said. I've got UV Blue tubing and distilled water (It's got Swiftech Hydrx in it, though it doesn't show through the tubes.) I still think you sould clean out your loop more often than a year though. I try for every 6 months.
Originally Posted by encorp
Code:
<firebane> slightly used
Old August 2, 2010, 12:29 PM
lowfat's Avatar
This is correct but it will not protect your blocks or the rest of your gear. Just the tubing.
Old August 2, 2010, 01:12 PM
MpG's Avatar
MpG MpG is offline
I have yet to see a comprehensive explanation on how the tubing does biocide duties. Are you saying it's contact only? In other words, stuff can't grow on the tubing itself, but the protection never actually enters the water itself?
Old August 2, 2010, 01:18 PM
element291's Avatar
hmm great point! i forgot that my res would just be plain and clear looking which sucks because its mounted right infront of my clear side on the case.
Old August 2, 2010, 01:21 PM
lowfat's Avatar
AFAIK this is exactly how it works..
Old August 2, 2010, 01:24 PM
gingerbee's Avatar
no matter what your using you should still clean your loop at least once a year imho. i try to do it every 6 months but i have been doing it so long some times i forget
Old August 2, 2010, 01:56 PM
dustin1706's Avatar
Like everyone has said, your best bet is uv tubing with distilled water. Grab a bottle of PT Nuke or similar biocide to add to your water for protection. The active ingredient is copper sulphate, so you could just go to a hardware/farm supply store and buy some.
UV dyes are really not the way to go, as you've seen, they tend to separate and cause problems. A good route to go if you want some color in your reservoirs (not UV though) is to use a mixture of automotive coolant with water. Just mix it about 25-50% coolant. You can get coolant in red, green, and blue from prestone that I've seen. The coolant also includes biocide and corrosion protection.
Old August 2, 2010, 02:00 PM
MpG's Avatar
MpG MpG is offline
Sigh. Well if so, that's a crock of shite on Primochill's part. Although I'll allow that I have yet to see any growth in my own main system, despite having my EK res right in the sunlight.
Ah well, at least I still have a couple bottles of pt_nuke kicking around. Really need to grab a chunk of silver one of these days.
Fesser coolant and 'other fluids" biff Water Cooling 16 January 16, 2012 01:19 PM
Quick Question Shonoby Display Units 2 July 9, 2009 03:58 PM
Quick Question /b/ derrXIII Video Cards 2 August 12, 2008 02:55 PM
Quick question Nodscene Power Supplies 2 July 7, 2008 11:27 AM
Quick Question. Khronos Display Units 2 January 7, 2008 01:16 PM
