Old August 1, 2010, 08:02 PM
lowfat's Avatar
Default SLI/crossfire fittings
I just bought another two GTX460's and plan to use three of them in my system. Now I've never used full cover blocks in SLI before. I plan on using 3 Koolance VID-NX460 blocks. If I buy stubby fittings will they be able to fit between the video cards? Or do I need something even smaller? I'd rather not have to spend $50 on those wierd SLI fittings w/ plastic tubes.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 1, 2010, 08:13 PM
JD JD is offline
Depends on your slot configuration I'd imagine.
I think you can use Bitspower D-Plugs though. They come in varying lengths and are solid brass in your typical BP colours. And of course there's the more common metal-tube fittings which I think Koolance makes.
Never seen any of these plastic tube ones though. Using stubby fittings may work too, but I'm guessing it'll be a bit tight getting tubing in?
Old August 1, 2010, 08:17 PM
lowfat's Avatar
I could always throw the tubing on before I throw the cards in their slots if need be.. I really perfer the look of black tubing w/ black fittings versus the metal/acrylic tubes used or compression fittings. Bitspower makes the clear acrylic.
Queen of Dreams WIP
Big Lian Li
Complete
Old August 1, 2010, 09:17 PM
JD JD is offline
Hmm guess I missed those BP acrylic ones. Interesting idea though.
I think you'll be able to do stubbys and tubing. Just have to be a bit more precise with the cutting/measuring I suppose.
Still can't fathom having multiple cards watercooled. It would just be such a pain in the arse if one card died, or needed to be removed for some other reason. I surely don't look forward to the the hassle I'd have to go through if I wanted to pull my HD5870.
Old August 25, 2010, 08:37 PM
lowfat's Avatar
Just to let everyone know, you can't use stubby fittings for the normal two slot SLI/CF. I ended up cutting a centimeter off a couple of fittings to get it to work temporarily.
Queen of Dreams WIP
Big Lian Li
Complete
Old August 25, 2010, 09:36 PM
Jackquelegs's Avatar
TFC - SLI VID Connector - G 1/4 - 1/2/3 Slot Retail SLI VID Connector - G 1/4 [1403] - $8.99 : DazMode, Canadian PC Water Cooling and Modding Store
For future references?
Iapetos
Zephyranthes
Old August 25, 2010, 10:05 PM
lowfat's Avatar
I was trying to cheap out.
Queen of Dreams WIP
Big Lian Li
Complete
Old August 25, 2010, 10:39 PM
Heh..well they aren't that expensive for only needing ONE
Iapetos
Zephyranthes
Old August 29, 2010, 11:49 PM
turtletrax's Avatar
I have always used D-Plugs. They work great. I got a couple spares around if you are interested, both the 1 inch and the larger one.
PM me if you need.
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
SLI-Crossfire mixed Cards? Why, yes please! Sagath Press Releases & Tech News 12 September 23, 2009 02:51 PM
Question on SLI Fittings axle182 Water Cooling 10 July 22, 2009 09:09 AM
anyone ever heard of this simular to sli and crossfire? Shadowmeph Video Cards 2 February 25, 2009 06:51 PM
sli & crossfire triumph Power Supplies 2 July 26, 2008 11:09 PM
crossfire Vs SLI enzeo Video Cards 7 December 19, 2007 11:55 PM
