I read the other thread regarding watercooling in the Antec 900, happy to see I'm not the only one attempting this. Anyways here we go:
I have bought the following setup:
Rad: Thermochill 120.3 with the Thermochill G3/8 barbs
CPU water block: Fuzion with flow accelerators
Northbridge Waterblock: Enzotech SNBW-SLI Sapphire
GPU water block: Swiftech MCW60-R GPU Water Block + bracket (water cooling a HD2900XT)
RAM/mofast heatsinks: Swiftech MC21 + Enzotech BMR-C1 + Enzotech BCC9
Radbox: Swiftech MCB-120 Radbox
Reservoir: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Pump: Swiftech MCP655-B
Swiftech Smartcoils 625 Blue
Masterkleer Pvc Tubing 7/16IN
Arctic Silver 5
5x Yate Loon D12SL-12 plus a tricool (going to remove the tricool when I make my next purchase at NCIX)
Lots of Swiftech there
Anyways, I have read a number of threads and articles and was wondering if anyone had any recommendations for my first water cooling build. As well as my first unassembly of the stock cooler on my GPU (lots of firsts). I know about heating the tubing (it's going to be a very tight fit onto that pump!). Anyone else have any suggestions for a first timer?
How did everyone here clean their thermochill rad, I heard about using vinager, however the instructions clearly states hot water only, suggestions?
As for the water cooling, I'm beginning to map it out in my head.
Anyone know if I could successfully mount my HDD in the top compartment with my DVD/CD drive? The reason I'm asking this, is because I'd put the resvoir in the middle and my pump in the lower section if this was possible. I'm mainly concerned about the cooling of the hard drive up there and vibrations, sure I could mod it somehow. Anyone done it before?
I'm thining about the following for my loop
res>pump>rad>CPU>NB>GPU>res
good or bad idea?
Any suggestions are welcomed as I want to get this right the first time, for obvious reasons.
James
