Old July 30, 2010, 04:28 AM
Smoothie's Avatar
Default Need help with Water Cooling Project
Hey everyone,
I was wondering if you can give me some pointers and help with some parts for water cooling. I'm confused about the bits/fittings/compression fittings/barbs for my build and need advice on what to get. Currently I have or will get the following:
Pump: Swiftech MCP655 (Plan to get this soon)
CPU Block: Heatkiller 3.0 Limited Edition (I already own)
Rad: Black Ice GTX Xtreme 360 (I already own)
Tubing: Tygon Tubing or Permochil
Tube Coils: Primochill 3/4IN Anti-Kink Tube Coils UV Red
Fans for the RAD: Delta or Scythe Ultra Kazes
Reservoir: Unsure of at the moment.
Fittings/barbs/bits/compresssion fittings: Unsure, need help
Xtop: I was wondering what does the Xtop do for a pump? I tried looking with google and didn't find any clear answers...
Any help would be most welcome.
Old July 30, 2010, 10:17 AM
New to WC myself and just waitin for my parts to come in. Read lots of stuff from ocn xs and google searches. For pump tops specifically yours you can read this which is a review for the ek top. Had alot of problems with fittings myself until i ran into youtube video below which explained alot. Hope this helps.
YouTube - EN Watercooling Basics: Fittings 101
Old July 30, 2010, 11:56 AM
Fudd Rucker's Avatar
You are going to need 1/2" ID 3/4" OD fittings, compression fittings are great for ensuring good seals and dont need clamps, as for barb fittings your going to need clamps. . As for the xtop, i never got the point of it since i have dual 5.25" bay resevoir.
I couldnt think of something snarky or interesting to put here this time around.
Old August 1, 2010, 07:15 PM
Smoothie's Avatar
Im thinking of a dual 5.25" Res that can hold the MCP655, any thoughts on this?
Old August 2, 2010, 12:35 AM
bottle's Avatar
Yes, don't do it.
Apparently bay reservoirs with the pump attached has caused many problems in the past (e.g T3).
However, I personally have a T3 rev.A myself and haven't had problems for almost 6 months now. Although I am waiting patiently for the derlin T4 to come out.
Some say the XSPC variant should be fine, I wouldn't know though.
Many would recommend tube reservoirs (EK water blocks) as I believe they have the least probability to crack, for reasons I do not know.
Old August 2, 2010, 06:41 AM
steers's Avatar
The XSPC dual-bay D5 unit is built pretty solid from how it looks, but I'm waiting until I can afford my second radiator before I upgrade the loop to test it out.
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old August 3, 2010, 05:40 AM
Smoothie's Avatar
Ok so I have decided to get compression fittings and a tube Res. Im looking into it and will order from Dazmode. I have to do some other upgrades to my PC first though.
Old August 3, 2010, 06:08 AM
Babrbarossa's Avatar
I do recommend the EKs, but not because they don't crack- my first one split up the side. If this one does, I will reconsider them as a useful component. I do like them because they're practical and look good- easy to set up with a fillport and lots of tubing configurations availabke. I dropped my mcp655 in favor of the 355 because they can attach to the bottom of the res with a fitting which saves a lot of space and looks good. (also, the lower flow rate is better suited to my boreas)
psst, wanna see my binder?
Old August 3, 2010, 09:08 AM
Aaah bloody hell just get a Swiftech Mcres Micro and call it a day.. It looks ugly, but it does the job.. :p
I've been a fan of barbs and worm clamps, but compression fittings seem to be taking over the water cooling industry now..
Tubing, definitely Primochill, period. Anti-Kink coils, don't think you'll need them, good to have though.
Gotta agree with Babr for 355 and res, no need to run extra tubing, plus saves more space, but the choice depends on what you're cooling, some cases you need a 655 since it does a better job.
Old August 3, 2010, 05:50 PM
Smoothie's Avatar
Bahh too many options lol. I will get it sorted out.
First water cooling project, how does this look. guitarguy Water Cooling 18 June 17, 2010 05:23 AM
Water cooling project has begun nckid4u Water Cooling 0 May 19, 2009 05:04 AM
My Antec 900 internal water cooling project b1lk1 Water Cooling 8 March 24, 2008 10:35 AM
Water Cooling Project lcdguy Water Cooling 4 March 19, 2008 01:41 PM
My First Ever Water Cooling Project zlojack Water Cooling 37 February 6, 2008 08:10 AM
