Originally Posted by t_mo_t everything is goood except that i would've gone for mcp655 and NON-bay reservoir
Btw, i bought 2x 6.5ft tubing and only used 1... in a HAF932 case, from the top fill port -> EK150 (and drain port to the bottom of the case) -> MCP655 -> HWL 2x120 -> EK Supreme HF
U could buy extra if u didnt cut the tubing some extra lag |
Thanks! Mind posting some pics of your setup? I also have a 932 - Figured bay res was good...so it fits in bay! I'll check out some non-bay res's. Are box res's okay and just not bay res? Or should I be looking at tube only res's? I really wanna try and jam the res where my 5.25 drives go as I have 4 slots available.
Originally Posted by lowfat I wouldn't go for that block. At least go w/ an EK Supreme HF. The classic does not perform as well.
Your tubing sucks. You may need to go elsewhere besides Dazmode for that though. 3/8ID 1/2OD tubing has horrible bend radius. I would highly suggest Primoflex LRT 3/8ID 5/8OD.
Otherwise everything looks good to me eh. |
Thanks, i'll see where I can find PrimoFlex tubing, as well as i'll get the EK Supreme block too.
