Old November 27, 2007, 07:52 PM
Default Gigabyte watercooling kit
I'm thinking of going the, water cooling way, I've pretty much looked at all the kits that are out there, from Swiftech, to Danger Den, NCIX kits.
The swiftech really gets good reviews, however I like the Gigabyte Kit, maybe because it's blue and it will match my case, the reviews seemed pretty good.
What is everyone else's opinion?????
Gigabyte 3D Galaxy II Liquid Cooling Kit LGA775 AM2 W/ CPU Block Pump & 120MM Radiator - DirectCanada
AMD Phenon II X4 965 3.4Ghz
Motherboard: Asus M4A78-E
Memory: Kingston HyperX 4GB DDR2
Video Card: Nvidia 8800GT
Harddisk: 2 x Western digital
CD/DVD Drive: Asus
Monitor: LG Flatron W2353V
Case: Thermaltake Armor
Sound Card: Sound Blaster Audigy
PSU: Thermaltake TWV 500W
Software: Windows 7
Old November 27, 2007, 08:18 PM
3.0charlie's Avatar
I really do like Gigabyte motherboards - heck, I own 3 of them. They're very good, stable and allow for high oc. But water-cooling? I checked their site, read the reviews. Let's say I'm not impressed. An E6400 running @ 2.5GHz, with load temps of 54C? I'll pass. Which Swiftech kit did you look at? You could also consider the NCIX Essentials 120. I did a review, and I'm really impressed. Reviewer Tryouts: NCIx Essentials 120 Water cooling kit.
John
Hydro-Quebec is salivating...
Watercooling the Antec 900 JD Water Cooling 44 December 10, 2007 09:13 AM
Help With Watercooling! Gasp! llama_egg Water Cooling 27 December 8, 2007 10:06 AM
Internal watercooling kit kING4000 Water Cooling 18 October 15, 2007 11:05 AM
questions regarding watercooling elninio Water Cooling 18 July 29, 2007 09:36 AM
Worklog : Watercooling a MM U2-UFO! Patriote Case Mods, Worklog & Gallery 3 May 15, 2007 06:40 PM
