Old July 10, 2010, 08:22 PM
Default Under water again
I think to go back on water. My budget is limited but i am thinking in the future to upgrade more.My case is a CM 690 II advanced. My list looks like this :
1) PUMP : - EK-DCP 4.0 or Swiftech MCP355(with a custom top)
2) RADIATOR : - Feser One X-120 or Swiftech MCR220
3) Fittings : - some 1/2 ID - 3/4 OD Feser or Bitspower
4) Reservoir : - i have a Swiftech MCRES-MICRO Rev 2
5) Tubing : - i have 10 feet of Primochill Primofles Pro LRT Black
6) Fans : - probably some Gelid or Yate Loon.
What do you guys think?
HEAT
Overclock.net
RFD
Old July 10, 2010, 08:33 PM
lowfat's Avatar
You don't mention what you plan on cooling or what blocks you will be using. However go w/ at least a 2x120mm radiator. The Feser 120 would be a waste pretty much.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 10, 2010, 08:40 PM
For now i will have only the CPU. The CPU block witch i will like to use is EK Supreme HF.
HEAT
Overclock.net
RFD
Old July 10, 2010, 10:20 PM
AmuseMe's Avatar
My little breakdown
MCP 355 with aftermarket top;
Hardware Labs SR-1 240/360/480;
Scythe Gentel Typhoons, or S-Flex "G" (on a fan controller);
EK Supreme HF or Heatkiller 3.0
Old July 11, 2010, 07:26 AM
Originally Posted by AmuseMe View Post
My little breakdown
I don't want to order from USA.
HEAT
Overclock.net
RFD
Old July 11, 2010, 09:31 AM
AmuseMe's Avatar
You can get all those parts in Canada.
Old July 11, 2010, 01:13 PM
Where i can find HW rads in Canada
HEAT
Overclock.net
RFD
Old July 11, 2010, 02:51 PM
ForTheGG's Avatar
Dazmode might have some.
Lian Li PC O11 Dynamic
Intel Core i5 4690K
Asus ROG Maximus VII Formula
EVGA GTX 780 SLI
8GB Corsair Dominator 1866
Samsung EVO 840 (1TB + 250GB)
Corsair AX850
Old July 11, 2010, 05:27 PM
AmuseMe's Avatar
I bought mine from NCIX. Looks like they do not have them anymore though...
Old July 11, 2010, 05:57 PM
lowfat's Avatar
If you are on a budget there is no reason not to go w/ an MCR*20.
Queen of Dreams WIP
Big Lian Li
Complete
new to water cooling LacrosseTown Water Cooling 11 May 19, 2010 01:50 PM
What is in the water?! encorp Off Topic 44 February 17, 2010 01:03 PM
Water is the best? magictorch Water Cooling 16 January 25, 2009 06:41 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
