Old July 12, 2010, 05:58 PM
you cant buy hw rads in canada right now that i know of. i actually bought out the last sr1 rad that ncix had in stock. go with daz for your gear but cross check prices with ncix sometimes they have a deal. get the hf block heatkiller is alittle pricey and not really necessary. as for rads its a question of fan speed mcr is good for low flow but doesnt cool that much and fesser cool alot but work better with higher air flow. o and id go with 3/8 instead of 1/2 cuz its easier and leaves u with more room and makes almost no difference in temps.
Old July 12, 2010, 06:09 PM
lowfat's Avatar
The only real difference between rads are looks. There is going to be less than 1C difference between radiators for most fans.
Skinnee Labs | Triple Radiator Comparison V2
Old July 12, 2010, 06:40 PM
Thank you guys for inputs. My setup :
1) PUMP : - EK-DCP 4.0
2) RADIATOR :Swiftech MCR220
3) Fittings : - some 1/2 ID - 3/4 OD Feser or Bitspower
4) Reservoir : - i have a Swiftech MCRES-MICRO Rev 2
5) Tubing : - i have 10 feet of Primochill Primofles Pro LRT Black
6) Fans : - probably some Gelid or Yate Loon.
7) CPU BLOCK : EK-Supreme HF PLEXI
next week probably i will order some stuff.
Lets get wet
www.miculhomereno.com
Old July 12, 2010, 06:56 PM
AmuseMe's Avatar
The only things I would change are the pump and CPU block, but they are personal reasons, not performance reasons.
I would get an (Swiftech) MCP-655 or 350/355. They are great pumps and are the most used ones in this hobby - and for reason. As for the CPU block, I would just switch the plexi for the full copper, or delrin. Plexi is prone to cracking, and the threads can be stripped much easier (not really a big deal if you do not re-do your loop very often.)
Just my opinion
DEAD CA$H
new to water cooling LacrosseTown Water Cooling 11 May 19, 2010 01:50 PM
What is in the water?! encorp Off Topic 44 February 17, 2010 12:03 PM
Water is the best? magictorch Water Cooling 16 January 25, 2009 05:41 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
