So yeah, went ahead, and sorted through all the parts, and found everything...other then two items. So far comes out to $208.94. All that's left is for me to pick up 3 Antec Tri-Cool fans (dunno if I'm going with LED lights on them or not yet...), the tubing, and if I'm not mistaken I need barbs. Oh, and the fluid. So yeah, by the end, probably around $300.
So, another question, what size tubing should I go for? The 240 Essentials says 7/16'', but I swear it looks as though it would only except 1/2''. *is confused*
Anywho, yay for part list;
Swiftech APOGEE GT; 44.99
Swiftech MCR320 Radiator; 44.99
Swiftech MCP655 Pump; 74.99
Swiftech MCRES-Micro Clear Hi-Flow Reservoir; 19.99
Swiftech MCB-120 Radbox; 19.99
Err...random barb here... Magicool Random Color Here UV Reactive Cable Ties; 3.99
Random Fluid Here Once again, random tubing here Antec Tri-Cool Fans x3; Price varies if I get it with UV lights or not
I beleive that's everything o_o
And The reason behind the random color is because I dunno what colors I want to go with yet
And once again, thanks for the continuing help! And that's alot of swiftech
