Old June 29, 2010, 09:36 PM
Default pumping
who thinks i can run a loop as follows off 1 655 pump?
res - 655 - 480 swiftech rad - ek gtx 480 - ek gtx 480 - 480 black ice sr1 rad - ek classified mb wb - ek supreme hf - res
orginal plan was 2 loops with 355's but if 1 655 can handle it ill go with that. share your thoughts.
Old June 30, 2010, 03:48 AM
why not running 2 pumps in one big loop, you get redundancy which is nice
Old June 30, 2010, 05:45 AM
martin_metal_88's Avatar
You can run 2 pump 1 loop or 2 loop but the 655 can handle the loop you want no prob.
Old June 30, 2010, 05:45 PM
Liu Kang's Avatar
You can run that with a single pump, but redundancy is extremely important IMO... if you have the budget and space for a second pump, do it. Lots of pump tops will allow you to run 2x655/355. G'luck.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
