-   Water Cooling (https://www.hardwarecanucks.com/forum/water-cooling/)
-   -   Plugging a pump to a mobo header ...? (https://www.hardwarecanucks.com/forum/water-cooling/3365-plugging-pump-mobo-header.html)
Synth November 23, 2007 07:47 AM
Would anybody advise against plugging a pump on a motherboard header? The pump in question is a DD CPX1 ...
Trying to tweak my cable management before leak testing !
Squeetard November 23, 2007 12:34 PM
Totally. You would pull way too many amps through the thin mobo traces.
MpG November 23, 2007 02:02 PM
That pump actually comes with a mobo header plug, if the pictures are any indication. It only pulls 6W (0.5 A), so I would think it would be doable. Heck, looking at one of my YL SL fans, they're rated to pull 0.30 A, and they're only rated at 1350 rpm.
Misoprostol November 23, 2007 07:15 PM
That pump is fine through a mobo header, but there aren't any other ones that I would recommend doing that with.
chibi_man November 23, 2007 07:35 PM
Yea. Those pumps require very little. Hell some fans have been said to pull more. I had a DD Mag2 hooked up, runs perfect and even can see the RPM on PC Probe as if it was a fan.
Synth November 23, 2007 10:01 PM
Alright, I'll try it out and hope for the best. Simplifies my cable management ... :biggrin:
chibi_man November 23, 2007 11:08 PM
On a side note. I prefer to use the motherboard to power it. Gives me some reassurance that the pump will always be on when I turn the bloody thing on. It's like a cooling nightmare for me.
Squeetard November 24, 2007 11:57 AM
I just enable cpu overheat protection in the bios and don't sweat it. I also have pc probe running with overheat alarms set.
You should probably disable any fan speed controllers you may have in the bios or windows. the lower voltages that spin your fans down under light loads may not be enough to run the pump at all.
