Old June 8, 2010, 08:01 AM
Default First water cooling project, how does this look.
Hi guys, so after many years of putting it off I've decided to go ahead and water cool my cpu.
My rig: i7 920, Gigabyte EX58-UD5, OCZ 6GB DDR-3 1600MHz, Sapphire 5850 xfire, Xigmatek 850 watt
The water cooling parts I have picked out are:
EK-Supreme HF Acetal 1/4 cpu block
Swiftech MCP655 pump
Swiftech MCRES-MICRO Hi-Flow reservoir
Swiftech MCR320-QP-K
If I decide to WC the dual 5850's will the pump ad radiator be good enough? Any suggestions to the build? I'm also going to need a new case. I was leaning towards the Coolermaster HAF 932 but was wondering if there are better cases for similar money.
Thanks!
Old June 8, 2010, 08:45 AM
gingerbee's Avatar
no your going to need more rad for whole the kit. but it will handle your cpu even if you overclocking. HAF is great case and very easy to water cool for that price range there's not much out there.
pump will do everything you want to do no problems at all great pumps. jmo
Old June 8, 2010, 08:53 AM
SugarJ's Avatar
Pump's good, block's good, rad isn't. You'll need a rad capable of dumping more heat if you're going to put your GPU cards and CPU in the same loop. The Swiftech rads are too thin to handle the heat load. Look at a Feser, HW labs, Thermochill, or XSPC triple.
Old June 8, 2010, 10:10 AM
Thanks for the input. Would the ThermoChill PA120.3 3x120mm be a much better rad?
Old June 8, 2010, 10:24 AM
I think you're definitely on the right track. Solid choice in parts! Sounds a lot like mine. I've had my 920 under water on my UD5 since day one.
I used to have the 920 and a GTX 280 on the same loop with a MCR320 and MCR220, all running off the MCP655 and it worked awesome.
You can check out my latest rebuild here to see pretty much how yours will look.
http://www.hardwarecanucks.com/forum...-rad-800d.html
Old June 8, 2010, 10:58 AM
SugarJ's Avatar
Absolutely. Although you could go with multiple rads like tehprofessor posted. Personally I prefer a single rad solution.
Old June 8, 2010, 12:00 PM
gingerbee's Avatar
see i may have gone swiftech stackable rads too may save some coin ( the only problem with the swiftech is it's thin physical size almost no difference between rads ) you just need more rad literally.
Old June 10, 2010, 09:49 AM
Is there a difference in performance between EK-Supreme HF - Acetal and EK-Supreme HF - Plexi?
Old June 10, 2010, 09:53 AM
Lpfan4ever's Avatar
Purely aesthetics.
Originally Posted by encorp
Code:
<firebane> slightly used
Old June 10, 2010, 01:14 PM
dustin1706's Avatar
Originally Posted by lpfan4ever View Post
Purely aesthetics.
Also plexi is more brittle and more prone to cracking if you accidentally over tighten your fittings or put stress on the fittings via the tubing. This is rare, but it does happen.
core i5 750 + hd 5970 water cooling build [in the process of ordering] kenshin1987 Water Cooling 32 June 11, 2010 11:23 AM
Water cooling project has begun nckid4u Water Cooling 0 May 19, 2009 05:04 AM
My Antec 900 internal water cooling project b1lk1 Water Cooling 8 March 24, 2008 10:35 AM
Water Cooling Project lcdguy Water Cooling 4 March 19, 2008 01:41 PM
My First Ever Water Cooling Project zlojack Water Cooling 37 February 6, 2008 08:10 AM
