Old June 5, 2010, 06:01 PM
Default core i5 750 + hd 5970 water cooling build [in the process of ordering]
So I'm thinking about setting up water cooling for my i5 750 and hd 5970. I currently have the i5 750 oc'd to 4.01ghz and my hd 5970 to 950/1300.
I'm thinking about getting this kit: Swiftech H20-220 Apex Ultima XT Universal CPU Liquid Cooling Kit - DirectCanada and this gpu block: NCIX.com - Buy Ek Water Blocks EK-FC 5970 Nickel Plated Full Cover Radeon HD 5970 GPU Block G1/4 - 3831109835142 In Canada..
My question is, will the stock rad be enough to handle the heat produced by the cpu and gpu or would I have to get a bigger rad?
Also, if possible I would greatly appreciate it if someone could put together a list of parts along with prices for a custom WC setup. Thanks!
Here's my system specs:
CPU: core i5 750
GPU: hd 5970
RAM: g.skill ripjaws 2x2gb
MB: asus p7p55d-e pro
PSU: seasonic m12d 850w
CASE: CM HAF 922
I've decided on the parts to get and here they are:
Pump: Swiftech MCP655
RES: Swiftech MCRES MICRO Rev 2
CPU Block: EK Supreme HF [ordered]
GPU Block: EK FC 5970 Nickel Plated Plexi [ordered]
Tubing: Swiftech 7/16" ID [ordered]
Barbs: Bitspower G3/8 1/2" (if I get thermochill rad), Bitspower G1/4 1/2" x 4 [ordered]
RAD: Thermochill PA120.3 [ordered]
Additive: Swiftech Hydrx water additive [ordered]
FANS: 2xNoctua P12 [already have], 1xYate loon D12SL-12 [ordered]
Total cost: $489
Old June 5, 2010, 06:16 PM
gingerbee's Avatar
I would not use it but i do not know how much heat the i5 750 makes go with a triple
Old June 5, 2010, 07:23 PM
AmuseMe's Avatar
That Swiftech rad will not even be close to enough. I would say it is almost not enough for the i5 at 4GHz. It is a thin rad. Most other rads like the HWL SR-1, Feser, EK, XSPC rads are twice as thick. Im thinking that it would be enough for the 5970, but not both!
Old June 5, 2010, 07:26 PM
I thought 5970s Dont run right on water...
Old June 5, 2010, 07:57 PM
what rad would you guys recommend?
Old June 5, 2010, 10:53 PM
dustin1706's Avatar
Check out this article: Skinnee Labs | Triple Radiator Comparison V2
The XSPC rads are fairly widely acknowledge as the current top dogs.
If you are planning on a Heavy Overclock and WCing your mobo and GPU, 1 XSPC RX360 would be the LEAST I would even consider trying. I have never looked into that case, but if it were me and I was looking for such an aggressive overclock, I would look at fitting a 4x120 OR a 3x120 on the CPU/MOBO and a 2x120 on the GPU.
The D5/swiftech655 is a good pump. Quiet and good flow rate, especially with an aftermarket top. Tubing and fittings of your choice. 1/2" ID recommended over 3/8" though.
Old June 6, 2010, 07:54 AM
Liu Kang's Avatar
That's your job, and half the fun of a build like this ;) Besides, without a budget, it's tough to provide advice. You're probably looking at anywhere from $400-$800 for your setup depending on the quality of components you want to run... rad(s), pump(s), pump top(s), fittings, tubing, reservoir and water blocks.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old June 6, 2010, 08:39 AM
lowfat's Avatar
As you can see buy the link dustin1706 posted, brands make very little difference in terms of performance.
Why the eff would someone spend $800 on watercooling.
He can easily get a system for under $400. That will work great. If he looks around for used gear he could spend even less.
From Dazmode.
From DirectCanada
Will be able to handle your setup w/ medium speed fans I'd think. People always under estimate how much a radiator can take if you crank up the fans.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 6, 2010, 12:19 PM
AmuseMe's Avatar
My loop is getting up there. It isnt cheap. I have said this before, but I know a guy who is running $1100 worth of radiators in one computer, and a $350 pump.
Don't buy that EK pump, its a gross Danger Den rebranding. Ewww! A rebranded DD pump
And you get what you pay for with Swiftech rads. You pay $50 for something that when you sneeze on, all the paint falls off.
Old June 6, 2010, 03:45 PM
dustin1706's Avatar
I have been pricing out my upcoming build, and for a very good dual loop D5 setup I am looking at ~500USD. Bear in mind that this is for an excessive setup that will likely last through several builds.
Custom Water Cooling Setup BALISTX Water Cooling 37 July 29, 2008 10:02 PM
Nub Water Cooling setup? thatguy Water Cooling 11 May 23, 2008 04:15 PM
Need help with first water cooling setup. BALISTX Water Cooling 18 March 23, 2008 10:11 PM
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 09:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 07:22 PM
