<~----> core i5 750 + hd 5970 water cooling build [in the process of ordering] - Page 4 - Hardware Canucks
  #31 (permalink)
Old June 11, 2010, 09:51 AM
lowfat's Avatar
Originally Posted by gomer View Post
if you want low noise black ice sr1 series is probably the way to go there abit more expensive but they perform better then a a normal rad with low flow fans. i just found a 480 sr1 at ncix as well 129.99 got it yesterday.
With 1000RPM fans the MCR320 actually performs slightly better.
  #32 (permalink)
Old June 11, 2010, 09:58 AM
The problem with a quad rad is that I'm not quite sure how I will mount it onto my haf 932 case.
I'm still unsure of which triple rad to get. According to this review: Skinnee Labs | Triple Radiator Comparison V2 most of the triple 120mm rads perform similar when using up to 1400rpm fans, which is what I will be using. However, the thermochill rad is also less restrictive than the other rads. Should I save the $30 and go for the swiftech MCR320 rad instead of the thermochill pa120.3?
  #33 (permalink)
Old June 11, 2010, 11:23 AM
what is 30bucks in terms of your whole watercooling gears? lol seriously, for just a difference of 30bucks, i would think in the long run
Custom Water Cooling Setup BALISTX Water Cooling 37 July 29, 2008 10:02 PM
Nub Water Cooling setup? thatguy Water Cooling 11 May 23, 2008 04:15 PM
Need help with first water cooling setup. BALISTX Water Cooling 18 March 23, 2008 10:11 PM
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 08:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 06:22 PM
