Originally Posted by Levesque I think you will be pushing it a little bit with a Tri-Crossfire set-up and an i5, all on a single triple rad. You could always put a second triple rad down the road when getting the 5870.
It depends on alot of things... What do you want to do with your system? If you like ''playing'' Furmark in extreme burning mode for hours, then those VRMs on the 5970 will get toasty pretty fast in a single triple rad loop (the 5870 VRMs are alot better and colder then those on the 5970...).
The other question is how much do you want to OC and push your voltages on your GPUs and your CPU? If your aiming for 1000/1300 on the 3 GPUs and 4.4-4.5 on your CPU, then 1 triple rad will not be enough.
But for regular gaming and the usual PC things, with mild/average OC, then there will be no problems. So it depends on your needs, and what you're planning to do with your system. |
Yea, I definitely won't be stressing the hardware anywhere near furmark stress test levels. I will be doing some overclocking (nothing too insane). Basically, I am not looking for ground breaking idle/load temps but I want them to be at least the same if not better than air cooling.
Based on what you said, I guess I will stick with a single loop triple rad setup for both my cpu + gpu, and will either add an extra rad or if I have to, setup a second loop when I go trifire.
Here's what my loop is looking like right now, please comment:
RAD:Thermochill PA120.3 Triple 120MM Fan Water Cooling Radiator with 15MM Spacing *No Barbs*
PUMP: Swiftech MCP655-B 12V Industrial Water Cooling Pump *Without Speed Adjustment* 1/2" Barbs
RES: Swiftech MCRES-MICRO REV2 Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
TUBING: Swiftech 7/16IN ID Vinyl Tubing 10 Feet
BARBS: Bitspower 1/2IN High Flow Nickel Plated Thermochill G3/8 Barb Fittings (2 Pack)
GPU BLOCK: Ek Water Blocks EK-FC 5970 Nickel Plated Full Cover Radeon HD 5970 GPU Block G1/4
CPU BLOCK: Apogee XT
