Originally Posted by kenshin1987 I am a bit confused on what size barbs I will need and does the size of tubing really make a big difference? If I can, I would prefer to use smaller size tubing since there is not much room to work with in a HAF 922 case. |
Bigger tubing means less restriction, but since W/C loops use such a short distance of tubing, the difference from 3/8 to 1/2" is minimal. The main thing is to use as few sharp 90* bends as possible, and don't have your tubing bending in such a small radius that it kinks. There are methods to get tighter bends such as anti kink coils or even hose clamps on the tightest part of the bend, or there are methods involving heat ing and cooling the tubing to make it conform tot he shape you need. Some of these "tricks" may be necessary in smaller cases.
The Swiftech MCP655 has 1/2" barbs that are built into the pump top and are not removable. There are other D5 pumps (the 655 is just a swiftech brand D5) with different/custom tops that allow you to use any sized barb you wish.
I would reccomend you go with 1/2" ID tubing, but if you feel that you need to use 3/8 to save room, that would work just fine, as long as you are aware of the 1/2" barbs on the 655.
