Old May 31, 2010, 01:27 PM
Default Coolit Eco - Should I, or shouldn't I?
Currently running a Phenom II X3 710, with Unlocked 4TH Core, using CM Hyper 212+. At normal room temperature, CPU is running at 31C idle, and about 41C load.
Think I'd see much of a difference if I switched to the Coolit Eco water-cooler? Ugh, so tempting, rebate available at TigerDirect.
If I use the Eco in place of the Hyper 212+, I'd also add a fan to the side-panel of my Antec 900. Think it's worth the move?
Old May 31, 2010, 06:20 PM
aviduser's Avatar
Well, what are you looking to gain? you still have thermal headroom if your into oc'ing.
The Eco may be a bit quieter than your hyper 212, I would guess the diff in temps would be 5 degress at most.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old May 31, 2010, 06:28 PM
rapmaster's Avatar
My 550 Unlock to 4 core at 4.08GHz at 1.55V with a 212+ with 2 R4. I don't think a 212+ limit your overclock unless you want silence.
Quando omni flunkus moritati
Old May 31, 2010, 07:12 PM
AmuseMe's Avatar
I don't think it is worth the move. I personally don't see it worth the price for the gain you would get.
Old May 31, 2010, 08:15 PM
^^^ Cool. I've made up my mind.
I'll stick with the 212+. Thx alot guys. Appreciate it.
H50 vs Coolit Systems Eco headsh0t Water Cooling 27 August 27, 2010 06:40 PM
CoolIT Reveals New ECO, Vantage, OMNI and Maestro Products SKYMTL Press Releases & Tech News 9 March 6, 2010 06:49 PM
Denim and Computers...something that shouldn't be combined aviduser Cases 15 December 22, 2009 11:25 AM
Any reason I shouldn't get a NORCO RPC-4220? Perineum New Builds 0 August 11, 2009 12:19 AM
