Old May 29, 2010, 09:19 AM
Dazmode's Avatar
Smile [Review] 2010 CPU Blocks RoundUp - Supreme HF, Apogee XT, Koolance CPU-360 and HK 3.0
After sinking countless hours into the test and putting my thoughts together, 2010 CPU Roundup was completed.
Full review is here: 2010 CPU Blocks Round Up
Here is the main chart. Note that scale has be stretched a lot to show the hair pin difference.
Orange Build: Final Video
HTPC Build: Final Video
Old May 29, 2010, 09:39 AM
AmuseMe's Avatar
Nice Daz. Basically it comes down to what the user think looks the best
Old May 29, 2010, 10:35 AM
Dazmode's Avatar
That is pretty much it, except of flow rates considerations. In this sense HF, CPU-360 and HK are likely perform better in multi-block setups, so gap should be wider.
Also for non-overcloked set ups the difference even smaller.
Old May 29, 2010, 06:52 PM
Looks the best and probably out of the few that did perform well, what is the cheapest, like since Daz's tests showed and mentioned Supreme HF winning by even a hair line, if that block is the cheapest possible with a lot of things included, then sure it wins.
The Heatkiller is still a favorite for many, but the high price and availability is what is against it, other than that, the craftsmanship is bloody darn good.
Tags
water blocks review
[Review] Koolance CPU-360 Dazmode Water Cooling 2 May 31, 2010 05:43 AM
[Review] Blowing dust from good ol' Supreme and Supreme LT Dazmode Water Cooling 0 May 5, 2010 05:01 PM
